    Pi 500 no audio. Volume slider resets to 0% @pi 5
    pi 5audio issue
    6 Posts 3 Posters 992 Views
      BenScoobert
      I know! Before you say it, Pi5 is not supported.
      But Tekken 3 would not run at full speed on my Pi4. It runs perfectly on the 5, but no audio on anything. It did exactly the same on my regular Pi5.
      All games run perfectly in retropie, but no audio.
      I did the install as per the instructions here https://github.com/danielfreer/raspberrypi5-retropie-setup?tab=readme-ov-file
      Here's a little video of how it behaves.
      Emulation Station V2.11.2RP
      RetroPie-Setup Script says Version 4.8.9
      I'm not that fluent with Linux but I fumble through with google and youtube.
      Any help is greatly appreciated.
      aplay -l
      card 0: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
        Subdevices: 1/1
        Subdevice #0: subdevice #0
      card 1: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
        Subdevices: 1/1
      aplay -L
      null
          Discard all samples (playback) or generate zero samples (capture)
      sysdefault
          Default Audio Device
      hdmi1
      softvolume
      softmute
      default
      hw:CARD=vc4hdmi0,DEV=0
          vc4-hdmi-0, MAI PCM i2s-hifi-0
          Direct hardware device without any conversions
      plughw:CARD=vc4hdmi0,DEV=0
          Hardware device with all software conversions
      sysdefault:CARD=vc4hdmi0
      hdmi:CARD=vc4hdmi0,DEV=0
          HDMI Audio Output
      dmix:CARD=vc4hdmi0,DEV=0
          Direct sample mixing device
      hw:CARD=vc4hdmi1,DEV=0
          vc4-hdmi-1, MAI PCM i2s-hifi-0
      plughw:CARD=vc4hdmi1,DEV=0
      sysdefault:CARD=vc4hdmi1
      hdmi:CARD=vc4hdmi1,DEV=0
          HDMI Audio Output
      dmix:CARD=vc4hdmi1,DEV=0
      • sugarfreeS
        sugarfree
        You have to manually set the audio output to HDMI by going to RetroPie Setup > Audio > HDMI. Then restart EmulationStation.
        I hope it works.
        (By the way, Tekken 3 is running at full speed even on the Raspberry Pi 3 at 720p resolution, so something else was the issue.(
        N 1 Reply Last reply Reply Quote 1
        • N
          Nash
          Does anyone have a working ES volume slider on Pi5? Does it exist?
          • N
            Nash @sugarfree
            @sugarfree In RetroPie Setup - configuration tools - audiosettings, I have :
            Mixer - Adjust output volume
            Reset to default
            Disable PulseAudio
            In Raspi-config - 6 Advanced Options - A7 Audio Config :
            1 PulseAudio
            2 Pipewire
            When PulseAudio is activated, Raspi-config - 1 System Options - S2 Audio
            does nothing, go back to main menu raspi-config.
            When Pipewire is activated, sometimes there is two otpions in Raspi-config - 1 System Options - S2 Audio :
            hdmi 0
            hdmi 1
            But nothing work, pi5 freeze when sound should play with Pipewire.
            In EmulationStation menu, it is always Audiocard : Default and Device : HDMI.
            sugarfreeS 1 Reply Last reply Reply Quote 0
            • sugarfreeS
              sugarfree @Nash
              @Nash I suggest opening a new topic and adding the requested information: https://retropie.org.uk/forum/topic/3/read-this-first.
              • N
                Nash @sugarfree
                @sugarfree Strange rule... "Don't talk about your problem with people who have the same problem."
                But it's ok, I go back to talk with myself on my topic.
