    Ace Gamer Wireless Controller for p4
    ace gamerdualshocksonyconfigurationcontroller
    3 Posts 2 Posters 364 Views
      andrewjrpi123
      Hi there! having troubles getting this controller configured. It's a cheap chinese clone of the Sony Wireless Dualshock. I am able to connect it via the bluetooth settings, but then when I try to configure it it isn't recognized by retropie. Any ideas on how to solve this one? Cheers
        Is it recognized as a joystick by the system (check dmesg after pairing it to see how it's detected) ? Does it work with jstest ?
          andrewjrpi123 @mitu
          @mitu I decided to use the Ace with my PS4 instead (it works fine right out of the box on PS4) and use the dualshock controllers for retropie. However, even those I can't successfully pair with retropie. I will write a separate post.
