    Emulationstation Shutdown Script Issue
    shutdownpoweremustation
    7 Posts 3 Posters 719 Views
    • TPRT
      TPR
      I added a very simple script to my front end on emulationstation to give myself a "shutdown" button next to all the consoles. Here's what I've done:
      In es_systems.cfg:
      <system>
      <name>power</name>
      <fullname>Power Menu</fullname>
      <path>~/RetroPie/roms/power</path>
      <extension>.sh .SH</extension>
      <command>sudo bash %ROM%</command>
      <platform>linux</platform>
      <theme>power</theme>
      </system>
      Shutdown.sh contains:
      sudo shutdown -h now
      The script actually works just fine and shuts down the system.
      Here's the issue...
      If I've added any games to my "favorites" folder in emulationstation, when I reboot the system, they are gone.
      If I use the original shutdown in the emulationstation menu, I can shutdown with the favorites still being there.
      Any idea what I'm doing wrong with that script that is causing the favorites not to get saved when the system shuts down?
      • sugarfreeS
        sugarfree
        t looks like your system is performing a hard/fast shutdown without saving metadata or favorites first, like RetroPie shutdown does.
        I believe this is related to EmulationStation. You need to find a way for EmulationStation to save the changes before the shutdown occurs.
        TPRT 1 Reply Last reply Reply Quote 0
        • TPRT
          TPR @sugarfree
          @sugarfree said in Emulationstation Shutdown Script Issue:
          Hmm… that would make sense. Is there a command to kill a process properly that shuts it down with saving data? I tried adding “kill emulationstation” in the script, which did work for shutting down es but same results with data not being saved.
          sugarfreeS 1 Reply Last reply Reply Quote 0
          • sugarfreeS
            sugarfree @TPR
            @TPR You have to make ES to save the changes not to kill it .
            You can try emulationstation -h in the terminal to see all available options.
            • TPRT
              TPR @sugarfree
              Doesn't seem to be much here for quitting the application:
              • LolonoisL
                Lolonois
                In ES there is a menuitem Save Metadata, set it to Always. Then you should be able to hard kill ES via shutdown/reboot without losing changes to gamelists / favorites / collections.
                TPRT 1 Reply Last reply Reply Quote 2
                • TPRT
                  TPR @Lolonois
                  @Lolonois said in Emulationstation Shutdown Script Issue:
                  BAM!!!
                  That worked!
                  Thank you! Not sure how I never noticed that option before! Almost seems like “always” should be the default.
