    Sound via 3.5 mm jack on GameSir G7 HE Wired Controller
    gamesir g7usb soundwired 360 pad
    3 Posts 2 Posters 320 Views
      gmarler
      Pi Model or other hardware: Raspberry Pi 4 Model B Rev 1.5
      Power Supply used: RAS-PWR13-PI
      RetroPie Version Used: 4.8, updated to latest via retropie-updater, as of 2025-04-07
      Built From: https://github.com/RetroPie/RetroPie-Setup/releases/download/4.8/retropie-buster-4.8-rpi4_400.img.gz
      USB Devices connected: GameSir G7 HE Wired Controller
      This shows up as the following in lsusb output:
      Bus 001 Device 003: ID 3537:1065
      Controller used: GameSir G7 HE Wired Controller
      I'd like to plug a headset into the wired GameSir G7, and disable the default Raspberry Pi on-board 3.5 mm jack.
      But I suspect I'm missing a driver that would allow me to do so, as there's no name associated with the controller's USB ID.
        Try installing the xone driver and then check with aplay -l to see if the gamepad appears as an audio output.
        EDIT: it looks like the driver wants a newer kernel then what's in the RetroPie image, it won't work.
          gmarler @mitu
          @mitu Thanks for confirming that.
          In the meantime, I was able to determine that my HDMI monitor also has a 3.5 mm jack that I never noticed before, so I can plug my headphones into that instead.
