    No sound on Raspberry Pi 5
    retropieno soundsound hdmi
    3 Posts 2 Posters 856 Views
      RealDave98
      Hey, I installed RetroPie on my Raspberry Pi 5 as described in the forum. Everything's working fine, but I have no sound. If I set the volume to 100% in the settings, for example, it resets every time. I've tried a lot of things, but unfortunately, to no avail.
        Did you went through the Sound menu (in the RetroPie system) to configure your audio output ? If not, then try setting it first.
          RealDave98
          @mitu said in No sound on Raspberry Pi 5:
          I tried it but it didn't work. After googling for a long time I found out that I had to install emulationstation-dev and now it works.
