    Zero Delay Encoder not recognised
    zero delay
    5 Posts 2 Posters 1.9k Views
      Pyjamarama
      Hi,
      I have been succesfully using a wired XBOX 360 pad and I decided to test my arcade stick.
      The problem is that I cannot get RetroPie to recognise my ZeroDelay based arcade controller! No prompt. No response.
      *It works fine on Windows
      *It works fine when I test it using jstest js0
      *The most strange: While my RetroPie was in screensaver mode (the screen was fade) when I moved the arcade stick stick it went off the screensaver (the screen got bright)!!
      Does it matter that I have the xboxdrv enabled?
      Any help appreciated.
      Thanx!
        Pyjamarama @Pyjamarama
        I still cannot understand why, although it recognises the ZeroDelay and jstest responds, EmulationStation does not pop up the Configure Controller dialogue for the new controller.
        At least, is there a chance to force the Configure Controller to be launched using a keyboard or cmd or something?
        If so, I guess I can map the controller.
          SORRY. I was plain silly!
          I went Configure Input and everything OK.
            Pyjamarama
            Back! :)
            In some (non libretro I think) apps my ZeroDelay does not go up and down! (left and right OK...)
            Any clues?
            • Z
              Zigurana @Pyjamarama
              @Pyjamarama
              Yes, that's likely to be this issue.
