    Save and Load State hot keys not work working on SFC30 gamepad.
    retropiesfc30
    9 Posts 4 Posters 3.5k Views
      silentq
      I was checking out my newish SFC30 pad on my retropie and I noticed a weird problem. My hotkey (START+SELECT) for exiting works fine on this game pad but my hotkeys for save and load state (SELECT+ R) and (SELECT + L) respectivly are not working. Oddly enough L and R work in their intended way inside every emulator. I am not sure what the issue is, but I suspect it may be my config file file for the SFC30 here it is:
      input_device = "8Bitdo SFC30 GamePad Joystick"
      input_driver = "udev"
      input_r_btn = "18"
      input_save_state_btn = "18"
      input_start_btn = "22"
      input_exit_emulator_btn = "22"
      input_l_btn = "17"
      input_load_state_btn = "17"
      input_up_axis = "-1"
      input_a_btn = "11"
      input_b_btn = "12"
      input_reset_btn = "12"
      input_down_axis = "+1"
      input_right_axis = "+0"
      input_x_btn = "14"
      input_menu_toggle_btn = "14"
      input_select_btn = "21"
      input_enable_hotkey_btn = "21"
      input_y_btn = "15"
      input_left_axis = "-0"
      Are my save/load state commands not setup properly? I can't seem to figure it out?
      • FloobF
        Floob
        Its "Select" that enables hotkeys, not "Start".
          silentq
          @Floob My apology I meant SELECT. I edited my issue. Still doesn't work with Select.
            edmaul69 @silentq
            @silentq what systems is this happening in? have you tried giving better permissions to to folder you are trying to save in? By default the /home/pi/RetroPie/roms/"name of system" i just give permissions to the whole roms folder. Works for me after i do.
              silentq
              Tried in NES/SNES/Genesis what's odd is the same hot key works with the DS3 so I am not sure if the SFC30 is different in some weird way?
                meleu @silentq
                @silentq This might be a dumb question, but here it goes: are you using RetroAchievements hardcore mode?
                  silentq
                  Nope no achievements.
                    meleu @silentq
                    @silentq Can you save/load state normally via RGUI?
                      silentq
                      Just checked, yes it works through the RGUI menu.
                      Update 1: very odd, the hot key works for the load state (SELECT + L) so it appears its only the save state hotkey not working.
                      Update 2: Ok so it appears I can save state but without any consistancy I have to spam it and if I spam (SELECT + R) too much it complete unpairs the controller and I have to re-pair it to get it working again. So perhaps its something just with the build quality of the SFC30?
                      Its not the worst thing I can always going in the RGUI and save/load.
