    Internal bluetooth for Pi3 won't work/start [SOLVED]!
    11 Posts 2 Posters 4.5k Views
      dannyboyswe
      No one can help me? Is there anyway to know if the board is faulty or not? :(
      • F
        FreakyBigFoot
        Did you update and upgrade? Try sudo apt-get install pi-bluetooth?
        • F
          FreakyBigFoot @dannyboyswe
          @dannyboyswe also I wrote a how-to on how to set up that controller with retropie. Need a link?
            dannyboyswe @FreakyBigFoot
            @FreakyBigFoot Yes, I have :(
              @FreakyBigFoot, it wouldn't hurt! Please, link me :D
              • F
                FreakyBigFoot
                I'd start over. Download the retropie image and flash it.
                Then follow this guide. Just do it top to bottom.
                https://www.reddit.com/r/RetroPie/comments/4d5hcf/how_to_setup_8bitdo_nes30_fc30_pro_controllers_on/
                  @FreakyBigFoot
                  That clip says it all! Thank you!!!
                  • F
                    @dannyboyswe did you use my guide? And did you start over?
                      @FreakyBigFoot, yes and yes :D Thanks again!
                      • F
                        @dannyboyswe Awesome!
