    Hi ! problem with psx
    psxretropie 4.0.2
    21 Posts 8 Posters 12.6k Views
      Barret
      Greetings friends. I'm starting in the world of Linux, and with the wonderful world of retropia, I like so much work to make a donation: D.
      But I have a problem with the relase 4.0, do not I get to run PSX, I do not get on the wheel menu.
      Directories think they are okay.
      Thanks for the help!
        Douggernaut
        https://github.com/RetroPie/RetroPie-Setup/wiki/Playstation-1
        Do you have .cue files in the /home/pi/RetroPie/roms/psx folder? Without any recognized game files, the emulator won't appear on the EmulationStation screen.
          PetroRie
          Do you have the PSX bios file in the bios folder?
            boris85
            Im habing a similar problem i have the bios in the correct file tried using caps and no caps, have the game files as .cue. they appear on menu but wont launch
              backstander
              @Barret
              You might need to goto the RetroPie Setup Script and install the lr-pcsx-rearmed and the lr-beetle-psx emulators. I don't believe they are already installed.
              https://github.com/RetroPie/RetroPie-Setup/wiki/First-Installation#installing-additional-emulators--ports
              @boris85
              In my /home/pi/RetroPie/BIOS I have these BIOS files with this case:
              SCPH1001.BIN
              scph5500.bin
              scph5501.bin
              scph5502.bin
              If those are not working for you, you might try downloading them from a different site.
                boris85
                Hey guys i tried both suggestions and both failed....any other suggestions? Better yet is there anywhere i can get a copy of all the working emulator files from like a member of this site?
                  backstander
                  Hey @boris85 did you try installing the other PSX emulator lr-beetle-psx from the RetroPie Setup Script?
                  When you load up a game from inside EmulationStation, you can press a button on the controller immediately at the Runcommand to get a menu that you can use to change the emulator (either per-rom or default for all PSX games). Try lr-beetle-psx and see if you have any better luck?
                    boris85
                    I will try that the next time i am on but im slowly giving up as all the emulators jave problems with them an i dont have that much time on my hands...still need to work out dreamcast, n64 and mame. 4 days so far on psx alone
                      dankcushions Global Moderator
                      beetle will be unplayabley slow on a pi. lr-pcsx is the only option.
                      OP, you're not giving us much info here. show us the exact file name of your BIOS file and where you have it, and the same for all the files for the game you are trying to run. the problem will be in one or both of these things.
                        boris85
                        I have all roms as .cue in rom/psx folder and it shows on play list in emulator and the bios are in the bios folder i put scph1001.bin in here tried under various typings still nothing
                          dankcushions Global Moderator @boris85
                          @boris85 said in Hi ! problem with psx:
                          give us full written examples and paths.
                          .cue is the tiny cuesheet file. it needs to point to a .bin. give us the full path and name of both.
                          the bios is only acceptable in one format: SCPH1001.BIN - do that and then give us the full name and path.
                            boris85
                            Retropie/roms/psx/abesoddworldoddysey.cue.
                            And retropie/BIOS/SCPH1001.BIN
                            dankcushionsD suprjamiS 2 Replies Last reply Reply Quote 0
                              and your game's bin file?
                              • suprjamiS
                                suprjami @boris85
                                @boris85
                                Your BIOS is in the right place, but you're missing the CD image.
                                The cue sheet is a description of a CD image.
                                Here's the Oddworld: Abe's Odyssey (U) 1.0 cue sheet: http://redump.org/disc/1858/cue/
                                Let's look at the contents:
                                $ cat "Oddworld - Abe's Oddysee (USA) (v1.0).cue"
                                FILE "Oddworld - Abe's Oddysee (USA) (v1.0).bin" BINARY
                                  TRACK 01 MODE2/2352
                                    INDEX 01 00:00:00
                                So to use this .cue file, we need a file called Oddworld - Abe's Oddysee (USA) (v1.0).bin and that .bin file contains the contents of the CD.
                                Does that make sense?
                                It may be easier to get PSX2PSP EBOOTs of the games you want to play. These are a single file with a .pbp extension. They work in the lr-pcsx-rearmed emulator.
                                  boris85
                                  Aah yes i understand the info i used to create the .cue file never mentioned anything about .BIN files aswell i will redownload later and put it on...how do i create or get a .pbp file if its simpler?
                                  suprjamiS 1 Reply Last reply Reply Quote 1
                                  • suprjamiS
                                    suprjami @boris85
                                    @boris85
                                    You can use an original image file and the program PSX2PSP, it's easy to find, but you need a working PSX CD image to start with.
                                    Or just search Google for "PSX on PSP eBoot ISOs" and you'll find many out there.
                                    You'll find most of them contain a directory and a file called EBOOT.PBP but that's just for use on a PSP, you can rename the file to whatever you want, such as Oddworld - Abe's Oddysee.pbp
                                      boris85
                                      Oh right i see so i would then get the eboot.php file and place straight in the retropie/rom/psx folder anf this should then work?
                                      suprjamiS 1 Reply Last reply Reply Quote 2
                                      • suprjamiS
                                        suprjami @boris85
                                        @boris85 Yes, that's right. You can also rename the EBOOT file, so you'd have like:
                                        RetroPie/roms/psx/Oddworld - Abe's Oddysee.pbp
                                          boris85
                                          Thanks ill give it a try later and get back to you how it goes
                                            edmaul69 @boris85
                                            @boris85 to rename the eboots i use a program i believe was called bulk rename. It can take all the folder names and rename all the files inside the folders the same name so you can rename all the eboots in a matter of minutes. Just make sure you unzip them all and place the different games folders in one common folder.
