CSL Gamepad configuration problems
Hey guys,
I bought two of CSL – USB Wireless Gamepad for PC incl. Vibration | Modell 2016 | Joypad Controller| Plug & Play | LED | Windows 10 compatible
(Btw I'm running Windows 7)
My problem is not to connect them to my laptop - this worked without any problem. My problem is that in the Zsnes emulator they are recognized as one and the same controller, which means offline multiplaying is impossible.
I already tried to fix the problem with Xpadder. On Xpadder both gamepads are recognized as individuals. Nevertheless, using them the problem still exists.
What can I do?
Best, bakbak
