    Raspberry pi3 picodrive is not starting
    pi3picodriveproblem
    9 Posts 4 Posters 2.9k Views
      spiderheiney
      I have reinstalled retropie multiple times now but everytime i try to start a sega genesis/megadrive rom it's not loading.
      When i switch to dgen the game runs but de controls are messed up.
      I would like to use picodrive because it uses the control mapping of retroarch.
      Does anybody else have this problem and does anybody know of a solution.
        BuZz administrators
        Please read https://retropie.org.uk/forum/topic/3/read-this-first which you agreed to when signing up on the forum.
        • Lyle_JPL
          Lyle_JP
          Just my opinion, but I find genesis-plus-gx to be superior to both of those emulators. It uses retroarch core remappings and is more accurate in emulation than both of those. It just doesn't run 32x.
            spiderheiney
            the only problem is that only dgen is working.
              spiderheiney
              for some extra information.
              i am using the pi 3 with the latest retropie v 4.0.2.
              i used both the preinstalled emulators ( picodrive and genesis-plus-gx ) with both of them when i run the rom the screen goes black and returns to retropie.
              The only emulator working is dgen.
                BuZz administrators
                What is the rom filename ? Please trigger the "runcommand" menu when launching (https://github.com/retropie/retropie-setup/wiki/runcommand) and choose option L Launch with verbose logging. Then post via pastebin.com the contents of /dev/shm/runcommand.log
                You can access that location using sftp.
                  spiderheiney
                  I finally figured it out the problem was that all the filenames had an # in it.
                  Somehow dgen had no problem with the filename but picodrive and genesis-plus-gx both had trouble with the extra symbol.
                  Glad i got it to work that part was giving me trouble for the past week.
                    BuZz administrators
                    Old Retroarch bug. No fix currently apart from renaming.
                      RetroResolution @Lyle_JP
                      @Lyle_JP I'll have you give that a try - I've been using Picodrive since RetroPie 2...
