    crt-pi shader users - reduce scaling artifacts with these configs in lr-mame2003, lr-fbalpha, lr-nestopia (and more to come)
    crt-pi shadercrt-picrt-pi-verticalshaderslr-mame2003
    385 Posts 42 Posters 353.3k Views
    • RiverstormR
      Riverstorm @Rion
      @Rion said in crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-mame2003:
      I got it working
      That's great! I know that variable is probably the issue. It's just my lack of knowledge of Python. You might try the line below. I think that will work. Basically you enclose in quotes before and after the cfgFileName variable concatenating it all as one string with the plus sign. It's a little more confusing with extra \ and " throughout the line but basically the same as before. Basically "string" + variable + "string" but we want double quotes to enclose the string after the = sign so there's two extra \" in the line. For example after +cfgFileName+ in the line if you remove the beginning and end quotes it's basically \" (double quote) and \n (new line).
      You probably know this :) but both the config file and overlay file are the same name: <game name>.cfg you would need to take that into account so they don't overwrite each other. You could run write it out to another directory or run it in a separate folder.
      newCfgFile.write("input_overlay  = \"/home/pi/RetroPie/roms/mame-libretro/overlays/"+cfgFileName+"\"\n")
      RionR 1 Reply Last reply Reply Quote 1
      • RionR
        Rion @Riverstorm
        @Riverstorm said in crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-mame2003:
        I got it working
        Well that did the trick!
        Thank you. Now lets start looking at the Generic Bezel for vertical games... :)
          twd Banned @dankcushions
          This post is deleted!
            Sharkus
            BTW, I found that I needed to put the override .cfg files here to get them to work with Retropie 4:
            /opt/retropie/configs/all/retroarch/config/MAME 2003
              Dochartaigh @Sharkus
              I'm going to try this tonight! Thank you!
              I've done this manually twice recently! ...thankfully I only play around 100 MAME games total so there weren't too many vertical ones.
              • RionR
                Rion
                dankcushionsD 1 Reply Last reply Reply Quote 1
                  edmaul69 @dankcushions
                  @dankcushions so i created a folder called MAME 2003 in /opt/retropie/configs/mame-libretro added all the files and it didnt work. then today i updated rpie setup script then updated mame 2003 from binary and still doesnt work. still only sees the crt-pi.glsl i have tried many roms. i am on a pi 3 with retropie 4.01 but i updated retroarch yesterday and mame 2003 today
                      edmaul69
                      Since i have no special mame configs and since i couldnt get this to work so i just used bulk rename utility to add the .zip into the names.
                      • RionR
                        Rion @edmaul69
                        @edmaul69 strange.. I'm using RetroPie 4.1.
                        Have you tried the ones i posted?
                          edmaul69 @Rion
                          @Rion i just put yours directly in my roms folder since you already had the .zip in the name. I dont know what the folder name was supposed to be where to put yours in the fba config folder.
                          • RionR
                            Rion @edmaul69
                            @edmaul69 The ones i posted are for mame not fba.
                            But if your looking for fba look here
                              edmaul69 @Rion
                              @Rion i was talking about those fba ones. im sorry i didnt realise you had a mame set as well. do yours still go in a folder named MAME 2003? or do i keep them in the folder you get from the zip?
                              • RionR
                                Rion @edmaul69
                                @edmaul69 The ones i posted goes in to the rom folder not mame2003.
                                  dankcushions Global Moderator @Rion
                                  @dankcushions @Sharkus @Dochartaigh
                                  Updated for RetroPie 4.1
                                  mame2003-crt-pi-vertical-overrides-.zip.cfg
                                  mame2003-crt-pi-curvature-vertical-overrides-.zip.cfg
                                  Place these in you mame-libretro or arcade folder.
                                  how are these 'updated' for 4.1? the mame gamelist hasn't changed.
                                  also, whilst i appreciate your effort i think your alternative versions are confusing this thread and unnecessary. the ones i uploaded in my original post should work for anyone using retropie 4.1. your .zip.cfg overrides in the rom folder are a retropie hack made before retroarch supported per-game cfg overrides. there's no need for that approach any more, and maybe it won't always be supported.
                                  i think we should use the properly supported retroarch way as it has advantages. for example, if you use a .zip.cfg rom override with config_save_on_exit = true in your main retroarch.cfg, your per-game shader override will migrate to your main retroarch.cfg. this doesn't happen with the supported approach.
                                    dankcushions Global Moderator @dankcushions
                                    i see, the shader location has changed in 4.1. i will update my .cfgs.
                                    still, unless someone can give me a good reason for keeping the .zip.cfg versions, i will be cleaning up this thread
                                    RionR FloobF 2 Replies Last reply Reply Quote 0
                                    • RionR
                                      Rion @dankcushions
                                      @dankcushions
                                      Sorry about that i should have been more clear about the .zip.cfg files i posted. Do you want me to remove these and add the cfg files only or post both for people to choose?
                                      I have also posted this
                                      Mame2003 (0.78u6) Generic Arcade Bezel for every game with crt-pi-curvate (vertical & horizontal)
                                      And this
                                      crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-fbalpha 029739 (formerly lr-fba-next)
                                      Same here with only .zip.cfg files. Do you want me to Change these to and only post the cfg files or both?
                                        @Rion thanks! yeah for me the cfg files only should be the ones we use. i don't see the reason for the .zip.cfg ones going forward. i will update my initial post once i've re-run my script with the new shader directory.
                                        RionR 2 Replies Last reply Reply Quote 0
                                        • RionR
                                          Rion @dankcushions
                                          @dankcushions Ok i will update my posts with the cfg files during the evening.
                                          • FloobF
                                            Floob @dankcushions
                                            @dankcushions said in crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-mame2003:
                                            Is there a chance someone not on a new enough version of RetroArch will get confused why the retroarch based location/overrides dont work?
                                            Although I would hope as more and more people use the current version of RetroPie/RetroArch it shouldnt matter.
                                            J dankcushionsD 2 Replies Last reply Reply Quote 0
