    Case for RaspberryPi with ControlBlock?
    controlblockcustom case
    6 Posts 4 Posters 2.1k Views
      Septemberist7
      Does anyone know if there is a case for the RaspberryPi with the ControlBlock?
      If not, does anyone know where I can find the exact dimensions/locations of everything on both the RP and CB or at least an existing design with measurements so I can attempt to design my own. A friend of mine can 3D print the case for me, but I don't want to have it reprinted several times because I measured incorrectly. Also, I have zero experience with doing something like this, so having a working model/design that I can modify and build off of would help tremendously.
      PokeEngineerP 1 Reply Last reply Reply Quote 0
      • PokeEngineerP
        PokeEngineer @Septemberist7
        @Septemberist7
        Don't sweat it.
          Septemberist7 @PokeEngineer
          @RetroPieNerd
          Yes?
          • PokeEngineerP
            @Septemberist7
            Sorry, accidental post...
            Don't sweat it.
              kingtink
              any update on this?
                malamoney
                I am in search of an answer to this exact question. Anyone have any updates? Are there any cases that will hold the RasbberryPi3 and a ControlBlock attached?
