    Help with NES30 pro RetroPie buttons
    nes30 procontrollerretropie
    11 Posts 5 Posters 4.1k Views
      senthudas
      I got Nes30 pro and Raspberry pi 3.
      I have RetroPie Controller issue.
      I downloaded retropie. Configured all buttons and they work Only in RetroPie menu.
      In any game system I run, only buttons that work are Up, down, left and right.
      A, B, Y and X and other buttons Do not work.
      Anyone has solution to this??
      Please Help me. Thanks everyone!
      • Z
        zop78
        Did you configure NES30Pro to UDEV in Bluetooth configuration? And possible you need to try and enable 8bitdo mapping hack?, depending on the firmware on the controller.
          senthudas
          I updated the firmware of nes30.
          1. where do I go to configure nes30 to udev?
          2. how do I enable 8bidto hack?
          • Z
            zop78
            I assume you have the latest version of retropie, so its pretty easy. Its done on the bluetooth settings screen, see the link below on the offical wiki.
            https://github.com/RetroPie/RetroPie-Setup/wiki/Setting-up-an-8bitdo-Bluetooth-controller
              senthudas @zop78
              @zop78 I did that, still not working.
              Anything else I can do??
              • Z
                zop78
                You might have to reconfigure all of your buttons on RetroPie menu efter setting to UDEV and enabling or disabling the hack.
                If that does not work i am out if ideas, i got my SFC30PRO working that way.
                  senthudas @zop78
                  @zop78 ok let me try that.
                  I will let you know if that worked
                  FloobF 1 Reply Last reply Reply Quote 0
                  • FloobF
                    Floob @senthudas
                    @senthudas Please let me know which step in the Wiki isnt working for you and I'll check it out.
                    I tried a few different controllers so it should work without issue as long as you have the correct firmware and settings shown there.
                      auswear
                      Put the firmware back to 1.69 and it will work - http://8bitdo.com/nes30pro/Firmware.html
                      and for the SFC30, use 2.67 - http://www.8bitdo.com/sfc30/firmware.html (No matter what I did I couldn't get buttons working in-game with the 2 most recent firmwares).
                      • FloobF
                        Floob @auswear
                        @auswear If you follow the Wiki and let me know the first step that doesnt work for you, I will happily re-write it.
                        It will help if you post your controller file on pastebin, as any issues can often quickly be seen from that file.
                        The key factor is often making sure you have the correct firmware and hack on/off combination - this is shown on the Wiki.
                          Strik9ine @senthudas
                          @senthudas what eventually fixed this problem? I've got the same issue.
