    Added Roms not showing up
    added roms not
    20 Posts 11 Posters 89.2k Views
      DavidL
      so after I first got retropie up and running a through on a couple snes roms to see if everything was functioning I did this with the flashdrive method. after everything checked out I loaded the flash drive with every rom I have and loaded it onto retropie. everything worked perfectly except the newly added snes games didn't show up. They did transfer to the correct location on the sd card (retropie/roms/snes) but they just aren't being listed by emulation station. any ideas besides formatting throwing on a fresh image on the sd?
      All roms are uncompressed and all verified to work on my windows version of snes9x
      I'm running a pi 3 model b with retropie 4.0.2 installed with a pre made image from retropie.
        edmaul69 @DavidL
        @DavidL did you scrape the previous roms you put on?
          DavidL
          I did not scrape them.
            skorpien
            Just a question, did you copy them into sub folders in the snes directory? I know from experience that roms won't show up in ES if they're nested.
              meleu @skorpien
              @DavidL First, the dumb question: did you restart emulationstation after loading the .../roms/snes directory with roms?
              Now, something more appropriate: did you turn on the "parse gamelists only" option?
              If this option is ON AND you didn't scrape your roms, the games won't be shown in ES.
              Here is how to access this option:
              es_menu
              es_options
              @skorpien
              I use subfolders and everything works fine.
              S G 2 Replies Last reply Reply Quote 1
                skorpien @meleu
                @meleu said in Added Roms not showing up:
                @skorpien
                Interesting... Maybe it's just the emulator I was using? It was the Commodore 64 emulator. Thanks though, I just assumed they were all like that. Apologies for spreading misinformation.
                  DavidL
                  The system has been restarted after the snes roms were loaded.
                  None of the new roms are in subfolders, one of the original 2 snes games was in its own subfolder but the new one went directly into the roms/snes folder
                  The parse gamelist setting is off.
                  I ran the scraper this morning just for kicks and oddly enough I now have one of the newly added roms (F1 roc) showing up in my only subfolder (secret of mana)... F1 roc is most defiantly not located in that folder.
                  Now I'm completely baffled
                    dankcushions Global Moderator @DavidL
                    @DavidL
                    you should show us the current directory structure on your pi, via command line or a screenshot of it via FTP or samba or whatever.
                      DavidL
                      Hopefully this is what your looking for. as you can see there isn't any other games in the secret of mana folder. Even though it shows "F1 Race of Champions" there. I would post a screenshot of that but I haven't setup screenshots on the pi yet.
                        DavidL
                        well looking at my own screenshot figured it out. if I add the file extension (.smc) and reboot it shows up.
                        still doesn't explain the F1 game showing up in the secret of mana folder though. oh well
                          DavidL
                          If anyone has a good idea how to add the appropriate extensions to all of these quickly I'd be interested
                          • herb_fargusH
                            herb_fargus administrators @DavidL
                            @DavidL bulk file renamer. Also you should just find a normal set. No need for all the bazillion variants. Look up the different types of romsets and what they mean.
                              meleu @DavidL
                              @DavidL
                              Take this bonus:
                              (But first take this warning: USE AT YOUR OWN RISK!!!)
                              To append .smc to every file that has no extension in a specific directory:
                              find /home/pi/RetroPie/roms/snes -maxdepth 1 -type f -not -name '*.???' -exec mv '{}' '{}'.smc \;
                              Edit: We are here for learning, right? Trying to explain what is happening on that command.
                              • -maxdepth 1: do not go to subdirectories.
                              • -type f: look for regular files only.
                              • -not -name '*.???': ignore files ending with a dot followed by 3 chars.
                              • -exec mv '{}' '{}'.smc \;: execute the command mv with the found files to append .smc to them.
                              C 1 Reply Last reply Reply Quote 2
                              • N
                                Nightfire @herb_fargus
                                @herb_fargus
                                just to add, here's a couple nice programs that integrate into the context menu that both do batch renaming (I like Lammar better for the renamer). Some roms may not want to work cause there are 2 common file extensions (SMC // SFC), but you'll want to select all roms without a file extension and then 'add suffix' of .sfc OR .smc
                                Lammar Context Menu
                                http://www.wedev4you.com/Pages/Products/LammerContextMenu#tab3
                                FileMenu Tools
                                http://www.lopesoft.com/index.php/en/filemenutools/download
                                  DavidL
                                  Yea at first I was thinking every rom had a .srm file that also didn't have an extension. again by just looking at the darn file I realized how dumb I was being. After sorting out just a few .srms I batch renamed the rest. Transferring them to retropie now. fingers crossed.
                                  Thank you guys, I'm sure I'll be back with more dumb questions soon
                                    giantkiller @meleu
                                    @meleu Dude! You nailed this one. Alot of people are missing this.
                                      captnyesterday @meleu
                                      @DavidL
                                      Take this bonus:
                                      New to all of this and made an account simply to thank you for this bit of advice above (not just the instruction, but the explanation) . Sorry if this is a thread or necro, I tried to PM you, but couldn't figure it out ;)
                                        meleu @captnyesterday
                                        @captnyesterday after 1 year I'm glad to know somebody used it. You're welcome. :-)
                                          thenotwellman
                                          Thanks! Nice and clear and helpful. Appreciate it.
                                          • F
                                            foxyplayzmeow jr
                                            Well go to retropie,then go to file manager,now go to retropie,roms,(the console where you added roms),and check if they are there...if you have the roms in archives,that means the console deleted the direct access,to go to roms again,go to a snes game plsy it and click select and x at the same time,this will open a menu,push b and select settings,video,video filter,then select /,home,retropie,roms and the console,then select the game,select browse archive and select game file.
                                            I got the same problem,i made that,but now the problem is that my disk is write protected...and if i use a new usb,the archives aren't there...
