    Powerblock Drivers using USB drive
    powerblockusb driveretropiehardwarewifi
    2 Posts 2 Posters 1.0k Views
      seymourbutttz
      I just got a raspberry pi zero running Retropie and would like to add the Powerblock to it. Can I add the Powerblock drivers and the APT packages to the pi zero using a USB drive and if so how? I understand that using wifi or Ethernet would probably be easier but I don't want to add wireless or Ethernet capabilities to my pi zero.
        petrockblog Global Moderator
        The PowerBlock works with the Pi Zero! One way for getting the needed packages and files on the SD card could be to use a "bigger" Raspberry with Wifi or Ethernet to prepare the SD card.
