    Pi Zero, lr-snes9x-next and Retropie 4.0 HELP
    pi0snes emulatorretropie 4.2
    4 Posts 2 Posters 1.6k Views
      SIrRandall
      Is this disabled or not available for the Pi 1/0 Builds ? I know I checked everything updated the system and the retropie setup scripts. I have checked all packages in main, optional and experimental. If it is the case that the Pi Zero can't handle it and it's not available I am fine with that. I just want to know.
        SIrRandall
        Just curious if anyone knows.
          BuZz administrators
          yes. It's too slow.
            SIrRandall
            Thank you that is all I needed to know. Thanks again for the reply.
