    Help with Dreamcast (Reicast) ROM formats
    dreamcastretropie 4.0.2reicast
    6 Posts 5 Posters 21.5k Views
    • E
      Everett1954
      Hi when I download Dreamcast Game ROMs they are usually in two formats: ZIP or RAR.
      If I unzip or unrar them I end up with these two options.
      1. a .bin and cue file
      or
      1. about 5 files like track 1, track two and a very small .gdi file (ex 187 bytes)
      What do I need to do to make these usable with the Retro pie Reicast emulator?
      • anasazi29A
        anasazi29
        Just create you a folder for each game inside the roms/dreamcast
        Bin & Cue do not seem to work. Just GDI. The GDI file is the only thing that will show up in the Retropie menu.
        • N
          Nismo
          Also you can convert gdi to only one file chd and save space.
          Anyway this is a little old post...
          • E
            Everett1954
            Thanks for the help!
            vbsV 1 Reply Last reply Reply Quote 1
            • vbsV
              vbs @Everett1954
              @Everett1954
              I would recommend using the games from Redump set since their filenames contain the game name so you can put them all in the same folder and also they are usable with Reicast out of the box without conversion.
                Custonian @vbs
                @vbs Had a look on ReDump and i don't seem to be able to download the complete file, do i need to register to download from this site?
