    Weird rainbow square in top right corner of my screen.
    9 Posts 6 Posters 3.9k Views
      trantornator
      Like I wrote in the title, I have a weird rainbow square, permanently appearing in the top right corner of my screen. Just upgraded from a Pi1 to a Pi3 and this is new. It's there from the very moment the pi boots up through all the gaming and the like.
      Anyone know what it means?
      • herb_fargusH
        herb_fargus administrators @trantornator
        @trantornator means you need a 2.5A power supply.
          trantornator
          Thanks! Will it in anyway damage the pi if I run it for a while without the 2.5A?
          • herb_fargusH
            @trantornator I don't think so, there may be a chance for SD corruption maybe but idk.
              trantornator
              It should be ok then until I can get a new power supply on Monday. Thanks!
              • H
                Hellcube
                You can switch it of by adding
                avoid_warnings=1 in /boot/config.txt.
                More info http://blog.fraggod.net/2015/11/28/raspberry-pi-early-boot-splash-logo-screen.html
                • Drakaen391D
                  Drakaen391
                  I wouldn't recommend disabling the warning though
                  RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
                  Retropie (Latest Stable)
                  PiBox with Wind Tunnel Cooling System
                  senkunS 1 Reply Last reply Reply Quote 0
                  • senkunS
                    senkun @Drakaen391
                    hey look the Oil Pressure Warning and Engine Coolant Temperature Indicators are blinking red!
                    ahh, no worries they always do that, just turn em off.
                    • glennlakeG
                      glennlake
                      You can buy special black tape to put over the warning lights in you car. I don't think that would work as well on your monitor. :-)
