    Sound and Xbox360 controller not working
    controllersoundxbox360
    3 Posts 2 Posters 1.1k Views
      goryblasphemy
      controller
      Pi Model: RASPBERRY PI 2, MODEL B
      RetroPie Version Used: latest version
      Built From: I formatted, programmed, and installed all on my own
      USB Devices connected: USB to XBOX 360 controller, Keyboard (sk-8175), and Wifi receiver (which doesn't seem to working either, I can't connect wirelessly)
      Controller used: XBOX 360 controller
      Error messages received: none
      Guide used: I followed this guide https://howchoo.com/g/n2qyzdk5zdm/build-your-own-raspberry-pi-retro-gaming-rig
      and this guide https://github.com/retropie/retropie-setup/wiki/Setting-up-the-XBox360-controller
      I have read the forums nothing stands out as pertaining to my problem.
      How to replicate the problem: I have no clue.
      I installed everything that it says from the first guide on how to set it up. I installed ROMS and and can run them and play them with my keyboard but there is no sound. I attached my 360-controller via its USB cable to the top left port on the PI. It boots, the light on the controller comes on, the retroPi "Configure Input" shows 2 gamepads detected, but when I hold a button it does nothing and the controller is never configured. How do I go about fixing these problems?
      I also ran the .... and it still doesn't work.
      sudo apt-get update
      sudo apt-get upgrade
        edmaul69 @goryblasphemy
        @goryblasphemy how are you testing sound? You can try editing the /boot/config.txt by typing:
        sudo nano /boot/config.txt
        And look for the line that says:
        #hdmi_drive=2
        And change it to:
        hdmi_drive=2
        Then press "ctrl" + "x" to exit and "y" to save. Then reboot with
        Sudo reboot
          goryblasphemy
          I am just starting a game. I tried 3 different games but no sound with any of them.....hey its working thanks, that worked
