    In need of help with Dreamcast / NES/SNES, desperate!
    nessnesdreamcast
    35 Posts 8 Posters 16.6k Views
    • N
      najkks
      wow, you save that much space?
      i thought it was like a fifth of the total size.. and with my 1300 roms it will be some space, thanks for the tip! :)
      btw.. do i use 7zip (or what the name is) and create a zip-file for each and every game then?
      • N
        najkks @backstander
        @backstander
        it seems like your using Rar, correct?
        does it have to be 7-zip or winzip.. or will Rar do as well?
        suprjamiS 1 Reply Last reply Reply Quote 0
        • suprjamiS
          suprjami @najkks
          @najkks
          Only zip, and only for the systems which support it. Check the system wiki page for the supported extensions, eg: https://github.com/RetroPie/RetroPie-Setup/wiki/Nintendo-Entertainment-System
          • N
            najkks @suprjami
            @suprjami
            well right now im having problem with winzip, using the new 20-version
            i cant seem to zip all files in to many files!
            • N
              najkks
              maybe someone know of a better and easier program to creaty multiple zip-files of all games?
              • N
                najkks
                uhm.. nevermind, i just found that i can output ZIP even in Winrar :D
                anasazi29A 1 Reply Last reply Reply Quote 2
                  bobcat987
                  If you want to automatically pull North American files from a large zip bundle, first unzip the bundle into a directory. The result will be a directory filled with 7z files. If running on the pi, as opposed to a linux workstation, you will need to install 7z utilities for the next step with:
                  sudo apt-get install p7zip-full
                  Now, change to the directory with the 7z files and run the following command:
                  while read line; do i=$(7z l "$line" | egrep '\((W|U|UE|JU|JUE)\)( \([^\)]*\))?( \[!\])?\.[^\.]*$' | tail -1 | sed -e 's/^.* \(.*\)$/\1/g'); if [ -n "$i" ] ; then echo "Extracting $i from $line"; 7z e "$line" "$i"; fi; done < <(ls -1 *.7z)
                  This takes a while to run on a PC (10-20 min) and will take longer on a pi, but the end result is the extraction of all North American from the 7z files with very little manual work. After this just move the extracted files to the rom directory and you should be set. Using the totally made up file extension, .nes, the command would look something like this:
                  mv *.nes <rom folder>
                  • N
                    najkks
                    well i finally got about 20 Dremcast-games..
                    but at the same time i got some Saturn-games..
                    and every game in the same folder, how can i tell which game is for which console?
                    • anasazi29A
                      anasazi29 @najkks
                      @najkks WinRAR Tutorial with GUI, http://windows7themes.net/en-us/how-to-zip-multiple-files-into-individual-archives/
                        backstander
                        @najkks I use PeaZip but WinZip or WinRAR will both work, just make sure you are compressing the files using the Zip compression format. I used that picture before of WinRAR settings because I could tell you have WinRAR from the picture you posted :-)
                        Dreamcast games have the extension of .cdi
                        Sature games will have an extension of either .bin .iso or .mdf
                        You just need to turn on show file extension in Windows 7 so you can see these extension:
                        http://www.thewindowsclub.com/show-file-extensions-in-windows
                        • N
                          najkks @backstander
                          @backstander
                          Yep got it, i have used the Winrar but with Zip-extension - works perfect! :)
                          is there any other games that i can Zip and still use?
                          seems like most for N64, NeoGeo, Master system etc.. wont be playable when zipped!
                            backstander
                            @najkks
                            If you go to the RetroPie official Wiki and down the far right side you see all the Emulators, well if you bring one of those up and look under Extension next to each emulator for that system, you'll see if it supports Zip as an extension.
                            For example:
                            If you pull up the PC Engine/TurboGrafx-16, then you'll see support extensions .pce .cue and .zip for both emulators so both of these PC Engine emulators support reading a ROM inside a zip file. I believe most of the RetroArch/Libretro emulators support zip files but the newer video game consoles (like N64, PSX, Dreamcast) might be best not to be zipped!
                            • N
                              najkks
                              Im trying to setup BIOS for dreamcast using this guide:
                              im at 8:26 in the video.. but NOTHING that he enters is doable on my retropie!
                              is there another and better guide out there? i havent found anything else..
                              This is what i get when trying to type in the same commands:
                                dankcushions Global Moderator @najkks
                                @najkks try cd RetroPie - it's case-sensitive
                                • N
                                  najkks @dankcushions
                                  @dankcushions
                                  hmm.. the games start without editing! is that how it should be?
                                  i just copied the BIOS-files to the correct BIOS (in Rpi) and started playing..
