    ppsspp not installing
    ppssppubuntuinstallation
    5 Posts 4 Posters 5.2k Views
      amenesesz06
      Yesterday my uncle said that he don't wanted his laptop so I take it install ubuntu and put all my roms there and searching for emulators I find retropie/ emulationstation, and my first reaction was "I need to install it, this looks awesome" so I install it and everything woks well, but ppsspp was not installed, I try the main package and the secondary one but it doesn't work the installation get at this point:
      Installing dependencies for 'lr-ppsspp' : PlayStation Portable emu - PPSSPP port for libretro
      ~/RetroPie-Setup/tmp/build/lr-ppsspp ~
      Getting sources for 'lr-ppsspp' : PlayStation Portable emu - PPSSPP port for libretro
      git clone --depth 1 "https://github.com/libretro/libretro-ppsspp.git" "/home/zawadzki/RetroPie-Setup/tmp/build/lr-ppsspp"
      Cloning into '/home/zawadzki/RetroPie-Setup/tmp/build/lr-ppsspp'...
      Submodule 'dx9sdk' (https://github.com/hrydgard/minidx9.git) registered for path 'dx9sdk'
      Submodule 'ext/armips' (https://github.com/Kingcom/armips) registered for path 'ext/armips'
      Submodule 'ffmpeg' (https://github.com/libretro/ppsspp-ffmpeg.git) registered for path 'ffmpeg'
      Submodule 'lang' (https://github.com/hrydgard/ppsspp-lang.git) registered for path 'lang'
      Submodule 'native' (https://github.com/libretro/ppsspp-native.git) registered for path 'native'
      Submodule 'pspautotests' (https://github.com/hrydgard/pspautotests.git) registered for path 'pspautotests'
      Cloning into 'dx9sdk'...
      Submodule path 'dx9sdk': checked out 'ec19e643461c84dbb256f6faaaab02cba61d4edc'
      Cloning into 'ext/armips'...
      Submodule path 'ext/armips': checked out '8bd93be9ba715d2f5723857edacf936ae904d07c'
      Cloning into 'ffmpeg'...
      and then it saids that it cant find a file
      everything else works great! this is the only issue that I have
      what can I do?
        BuZz administrators
        Please follow https://retropie.org.uk/forum/topic/3/read-this-first when posting as agreed when registering on the forum. Please format posts when posting, logs and include the actual errors displayed.
          Myke
          I have the same problem...
            backstander
            @amenesesz06
            The newest version of Ubuntu 16.10 isn't supported so to get PSP & N64 support, you should use Ubuntu 16.04:
            https://retropie.org.uk/forum/topic/4529/retropie-ubuntu-16-04-lts-x86-problem
              Myke @backstander
              @backstander
              I have a raspberry pi 3, and it turns out that same problem;
              I can't install ppsspp from binary, just from source;
              binary is locked on Setup screen and nothing happens;
              source displays the error mentioned above;
              This also happens when I try to install the emulated on the Dreamcast;
              but Dreamcast worked installing via source;
              Sorry i don't speak English!!
