    Anyone who knows Sega CD emulator and why it might not work?
    sega cdemulatorlr-picodrive
    32 Posts 3 Posters 13.8k Views
    • N
      najkks
      Ive followed the guide step by step..
      ensured that i have the correct BIOS, in the correct place..
      ive chosen the correct emulator (lr-picodrive) and everything
      still.. after ive tried to start the game - it goes straight out in the games-browser again, how can this be?
      would appreciate som hints :)
        BuZz administrators
        • N
          najkks
          Im using a Rpi 3b with latest retropie, i think its 4.01/4.03?
          Im using the LR-Picodrive, and set the correct BIOS-file in Retropie/BIOS/ (with the correct name)
          No usb-devices connected at the moment
          No Error-message (it just skips out to the games-list again when trying to start a game)
          Built from Retropie - nothing earlier what i am aware of
            BuZz administrators
            Please give example filename of game - is it unpacked ?
            what are the contents of /dev/shm/runcommand.log? (launch in verbose mode from runcommand menu) - you can paste the log on a site like pastebin.com or similar
            • N
              najkks @BuZz
              @BuZz
              the game is in a BIN/CUE -file, the same for both (for ex. Final Fight.bin / Final fight.cue)
              dont know if its allowed with spaces in filename though..
              sorry, but im not sure on how to run verbose mode...
                backstander
                @najkks
                Open up that "Final fight.cue" file with a text editor in Windows and make sure it has "Final Fight.bin" in that exact case (not all uppercase like "FINAL FIGHT.BIN"). If it doesn't have the exact case, fix it and save the file. You can do this in Windows before pushing it over to the Raspberry Pi. Do this with all your .cue files. File and folder names are case sensitive in Linux and in Windows they are not.
                Also every once and a while you'll run across one that has some thing like this
                FILE "C:\My Games\blah blah blah\FINAL FIGHT.BIN" BINARY
                and those you got to remove everything before the actually file name "FINAL FIGHT.BIN" and then retype it with the exact case as the file like "Final Fight.bin" like this:
                FILE "Final Fight.bin" BINARY
                  BuZz administrators
                  Check the cue file and make sure the name inside matches the bin file exactly (including case)
                  verbose mode is available from https://github.com/retropie/retropie-setup/wiki/runcommand (on the latest retropie-setup)
                  • N
                    najkks @backstander
                    @backstander
                    ive opened the cue-file in txt-editor, first line says: FILE "Final Fight CD (Sega CD) (U).bin" BINARY
                    so this means that i have to rename both ISO / Cue-file to exactly the same? (case sensetive ofcourse)
                    • N
                      najkks
                      well.. now ive tried two things!
                      1. open the cue-file and renaming the first line exactly like the title of the Cue / Bin -files
                      2. open the cue-file, check whats typed in first - and then changed the name of the cue/bin-files to that
                      netither worked!
                        BuZz administrators
                        I will need to see the log I mentioned earlier to advise further. enter the runcommand menu and choose the option Launch with verbose logging. Then from an ssh connection post the output of
                        cat /dev/shm/runcommand.log (use a site like pastebin.com for the log)
                          BuZz administrators
                          and the output from
                          ls -l ~/RetroPie/roms/segacd
                          cat ~/"RetroPie/roms/segacd/NAMEOFCUEFILE"
                          N 2 Replies Last reply Reply Quote 0
                          • N
                            najkks @BuZz
                            @BuZz
                            sorry but this is a step higher than i know of..
                            i dont know how to use / or enter the runcommand menu,
                            well i can enter it before the game tries to start, but i cant do anything else?
                              BuZz administrators
                              I linked to how to use the runcommand menu earlier.
                              I suspect the problem is still the bin/cue naming mismatch but I cannot advise without seeing how you changed it.
                              • N
                                najkks @BuZz
                                @BuZz yes i saw the link
                                but this i not understand:
                                  BuZz administrators
                                  So, enter the runcommand menu when launching the game. Choose the option in the menu to Launch with verbose logging then when it returns to the emulation station menu, ssh in to the system and run the commands I have given (making sure you substitute the cue file name)
                                  https://github.com/retropie/retropie-setup/wiki/ssh
                                  • N
                                    najkks
                                    ssh in to the system.. is that like dos?
                                    • N
                                      najkks
                                      well ive entered the run command menu, and run the game with verbose logging..
                                      its from this point im not sure where to go next..
                                      • N
                                        najkks
                                        could i use Putty to ssh in to the Rpi?
                                        ive checked the ip.. but what about login/password?
                                        • N
                                          najkks
                                          im in the Rpi now :)
                                          • N
                                            najkks @BuZz
                                            @BuZz
                                            pi@retropie:~ $ cat /dev/shm/runcommand.log
                                            Parameters: 0 _SYS_ segacd /home/pi/RetroPie/roms/segacd/Final Fight.cue
                                            Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libr        etrocores/lr-picodrive/picodrive_libretro.so --config /opt/retropie/configs/sega        cd/retroarch.cfg "/home/pi/RetroPie/roms/segacd/Final Fight.cue" --verbose --app        endconfig /dev/shm/retroarch.cfg
                                            RetroArch [INFO] :: Redirecting save file to "/home/pi/RetroPie/roms/segacd/Fina        l Fight.srm".
                                            RetroArch [INFO] :: === Build =======================================
                                            Capabilities: NEON VFPv3 VFPv4
                                            Built: Jul 17 2016
                                            RetroArch [INFO] :: Version: 1.3.6
                                            RetroArch [INFO] :: Git: 7a433a6
                                            RetroArch [INFO] :: =================================================
                                            RetroArch [INFO] :: Config: appending config "/dev/shm/retroarch.cfg"
                                            RetroArch [INFO] :: Config: loading config from: /opt/retropie/configs/segacd/re        troarch.cfg.
                                            RetroArch [INFO] :: Resetting undo buffers.
                                            RetroArch [INFO] :: Loading dynamic libretro core from: "/opt/retropie/libretroc        ores/lr-picodrive/picodrive_libretro.so"
                                            RetroArch [INFO] :: Overrides: no core-specific overrides found at /home/pi/.con        fig/retroarch/config/PicoDrive/PicoDrive.cfg.
                                            RetroArch [INFO] :: Overrides: no game-specific overrides found at /home/pi/.con        fig/retroarch/config/PicoDrive/Final Fight.cfg.
                                            RetroArch [INFO] :: Environ SET_VARIABLES.
                                            RetroArch [INFO] :: Remaps: remap directory: /opt/retropie/configs/segacd/
                                            RetroArch [INFO] :: Remaps: no game-specific remap found at /opt/retropie/config        s/segacd/PicoDrive/Final Fight.rmp.
                                            RetroArch [INFO] :: Remaps: no core-specific remap found at /opt/retropie/config        s/segacd/PicoDrive/PicoDrive.rmp.
                                            RetroArch [INFO] :: Environ PERFORMANCE_LEVEL: 0.
                                            RetroArch [INFO] :: Environ GET_LOG_INTERFACE.
                                            RetroArch [INFO] :: Environ SET_DISK_CONTROL_INTERFACE.
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_input1:
                                            RetroArch [INFO] ::     3 button pad
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_input2:
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_sprlim:
                                            RetroArch [INFO] ::     disabled
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_ramcart:
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_region:
                                            RetroArch [INFO] ::     Auto
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_region_fps:
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_aspect:
                                            RetroArch [INFO] ::     PAR
                                            RetroArch [INFO] :: Environ GET_VARIABLE picodrive_drc:
                                            RetroArch [INFO] ::     enabled
                                            RetroArch [INFO] :: Content loading skipped. Implementation will load it on its        own.
                                            RetroArch [INFO] :: Environ SET_PIXEL_FORMAT: RGB565.
                                            RetroArch [INFO] :: Environ SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
                                            RetroArch [libretro INFO] :: detected BIN Sega/Mega CD image with USA region
                                            RetroArch [libretro ERROR] :: Missing BIOS
                                            RetroArch [ERROR] :: Failed to load content.
                                            RetroArch [INFO] :: Monitor FPS estimation is disabled for threaded video.
                                            pi@retropie:~ $
