    Anyone who knows Sega CD emulator and why it might not work?
    sega cdemulatorlr-picodrive
    32 Posts 3 Posters 13.8k Views
    • N
      najkks
      pi@retropie:~ $ ls -1 ~/retropie/roms/segacd
      ls: cannot access /home/pi/retropie/roms/segacd: No such file or directory
        BuZz administrators
        Please try and follow my instructions carefully. I asked you to put the log on an external site like pastebin.com - on the forum is also fine, but you need to format it in a code block - http://commonmark.org/help/ - I will format your post for you.
        You did not type the ls command as I instructed - linux filesytems are case sensitive. RetroPie is not the same as retropie.
        From the log it looks like you have not installed the BIOS correctly.
        • N
          najkks @BuZz
          @BuZz
          hmm.. using pastbin.. i dont have enough priviligies to past the file here in the forum?
            BuZz administrators
            As I wrote above
            • N
              najkks
              sorry but i cant do other than post this right here:
              pi@retropie:~ $ ls -1 ~/RetroPie/roms/segacd
              32X_G_BIOS.BIN
              32X_M_BIOS.BIN
              32X_S_BIOS.BIN
              Android Assault.bin
              Android Assault.cue
              Dragons Lair.bin
              Dragons Lair.cue
              Earthworm Jim - Special Edition.bin
              Earthworm Jim - Special Edition.cue
              eu_mcd1_9210.bin
              Final Fight.bin
              Final Fight.cue
              Genesis_OS_ROM.bin
              jp_mcd1_9112.bin
              Mickey Mania.bin
              Mickey Mania.cue
              Popful Mail.bin
              Popful Mail.cue
              Robo Aleste.bin
              Robo Aleste.cue
              Sol-Feace.bin
              Sol-Feace.cue
              Sonic.bin
              Sonic CD
              Sonic.cue
              Terminator (Sega CD) (U).bin
              Terminator (Sega CD) (U).cue
              The Timeless Adventure of Mickey Mouse.bin
              us_scd1_9210.bin
                BuZz administrators
                The problem is the BIOS file anyway. You have the wrong bios / have installed it in the wrong location or the filename is wrong
                Please check https://github.com/retropie/retropie-setup/wiki/Sega-CD noting the filenames and remembering that the names are CASE SENSITIVE.
                  BuZz administrators
                  Please actually read http://commonmark.org/help/ and use a code block as detailed if posting to the forum. if you are unable to use markdown, use an external site like pastebin.com or http://paste.ubuntu.com/
                  • N
                    najkks
                    Do i need all three of each BIOS /files?
                    isnt it US / EUR / J ?
                    ive checked and my bios-files are named exactly the same as the ones on Github
                      BuZz administrators
                      No. You haven't read the wiki page
                      The BIOS filename is: us_scd1_9210.bin
                        BuZz administrators
                        What is the output of ls -la ~/RetroPie/BIOS/us_scd1_9210.bin ?
                        • N
                          najkks
                          I got it running :)
                          used a totally different ISO-bios and changed it name!
                          well thanks for the help :)
                            BuZz administrators
                            Please mark topic as solved
