    sound issues with sega system 16 games
    mamearcade
    9 Posts 2 Posters 2.8k Views
      juice
      hi guys , i have all the mame games set up through multiple emulators , i am using fba next and mame 2003 and 90% of the games play solid on my pi3 running floobs attact mode with retropie.. i haveing problems with the sound of golden axe, altered beast, etc samples sounding very scratchy. has anyone got round this issue thanks
        BuZz administrators
        Have no idea about your set up - please read https://retropie.org.uk/forum/topic/3/read-this-first
        which emulator for which game ? which version of retropie etc . thanks
          juice
          sorry mate, here you are
          emulators used - lr-fba-next - lr-mame2003
          Pi Model: (pi3)
          RetroPie Version Used: RetroPie 4.0.1
          Pre made SD Image from floob retropie 4.0.1 with Attract Mode 2.1.0 )
          USB Devices connected: usb wireless synic keyboard
          Controller used: xbox 360 pad
          like i said over 90% of games working no problems, but the sound in sega system 16 games ,golden axe, altered beast ,moonwalker, eswat etc. i have looked through all the different rom list to see compatiblity and they look fine in there
            BuZz administrators
            outrun was fine when I tested in lr-mame2003 on my raspberry pi 3 afair.
            What PSU are you using ?
            https://github.com/retropie/retropie-setup/wiki/Overclocking#power-supply
              juice
              the power supply from pi hut everything came in a kit
                BuZz administrators
                assume it's this one ?
                https://thepihut.com/products/raspberry-pi-3-starter-kit
                please can you posts via pastebin.com or in a code block on the forum the contents of /boot/config.txt
                and the contents of /opt/retropie/configs/mame-libretro/retroarch.cfg and /opt/retropie/configs/all/retroarch.cfg
                  juice
                  how do i access these directorys i only can access this directory from the network on pc \RETROPIE\configs\mame-libretro there an config file there. and outrun sound is fine on mine , it the above games mentioned thanks.
                    BuZz administrators
                    https://github.com/retropie/retropie-setup/wiki/ssh
                    it is of course those games don't run well - I would need to test.
                      juice
                      i have solved the problem , a user on here told me to use mame2010 for the sega games and they all work soild now with the sound.
                      thanks for your help
