    Final Burn Alpha 0.2.97.39 is out!
    mamearcadelibretro
    37 Posts 12 Posters 38.4k Views
    • RionR
      Rion
      A lot of Fixes and new features, Clones and updated romsets in existing drivers, New additions to existing drivers and so on..
      Changelog
      The latest version was pushed into libretro-fba
      FBNeo rom filtering
      Mame2003 Arcade Bezels
      Fba Arcade Bezels
      Fba NeoGeo Bezels
        BuZz administrators
        Good news - thanks.
        If anyone would like to give it a bit of a test - I can then update the binaries etc.
          BuZz administrators
          Also I just saw - https://github.com/libretro/fbalpha/commit/003922b9317af073008021e39eac6bafa819e071
          awesome!
            Twitch0815
            I will test for sure just let me know when the binaries are ready.
              BuZz administrators
              I won't built new binaries until someone has tested it a bit, so you could build from source now and give it a spin :-)
                Twitch0815
                Pretty smooth thus far, The bugs are noted in the blog,
                Rtype works.
                RionR R 2 Replies Last reply Reply Quote 0
                • RionR
                  Rion @Twitch0815
                  @Twitch0815 What blog?
                  FBNeo rom filtering
                  Fba Arcade Bezels
                  Fba NeoGeo Bezels
                    I think the big question is: Does it keep working with the 0.173 ROMset?
                    [edit]
                    In the "Fixes and new features" section says:
                    • Sync. romsets with MAME 0.175 [Barry]
                    And in the "Clones and updated romsets in existing drivers" section says:
                    • [...Added a bunch of ROMs]
                    • Updated The King of Fighters '99 (15th Anniversary Edition) to 20160827 Build [JacKc]
                    • Updated The King of Fighters '98 (Combo/Ivex Hack) to 20161004 Build [JacKc]
                    Are these two ROMs from 0.173 the only affected by this update?
                    [edit2]
                    I updated the Managing Roms wiki. The lr-fba-next gamelist link (that in the "# of ROMs" column) was pointing to the most uptodate gamelist.txt. Now it's pointing to the specific 0.2.97.38 version.
                    Question: the wiki says that lr-fba-next has 4150 games, but the gamelist.txt says "8779 games supported". Where did this 4150 come from?
                    • RionR
                      Rion @meleu
                      @meleu said in Final Burn Alpha 0.2.97.39 is out!:
                      • list itemSync. romsets with MAME 0.175
                      You have to update to 0.175
                      FBNeo rom filtering
                      Fba Arcade Bezels
                      Fba NeoGeo Bezels
                        meleu @Rion
                        @Rion In the "Clones and updated romsets in existing drivers" section says:
                        • [...Added other ROMs]
                        • RionR
                          Rion @meleu
                          @meleu
                          The best way to away keep up to date on Mame/Arcade is to have the latest Mame and Mame Rollback Roms.
                          I have not rebuild FBA yet to correspond to Mame 0.175 so i cant say.
                          But i do regularly update my Mame sets when new versions come out.
                          FBNeo rom filtering
                          Fba Arcade Bezels
                          Fba NeoGeo Bezels
                            Pyjamarama
                            The romsets update (in general) is killing me :)
                            • DarksaviorD
                              Darksavior
                              Anyone get cps2 games working? None work for me. I'm not 100% sure my games are updated..I just extracted update packs upto 0.175.
                              woops. here's my log:
                              Parameters: 0 SYS fba /media/usb0/fba/sfa3.zip
                              Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fba-next/fbalpha_libretro.so --config /opt/retropie/configs/fba/retroarch.cfg "/media/usb0/fba/sfa3.zip" --appendconfig /dev/shm/retroarch.cfg
                              Update: Tried it on pc mame since that'll spit out an error that will help me. Looks like it was missing its .key file. I guess these updates packs didn't update the cps2 games
                                Twitch0815
                                Yea tested a few and they are working. Just using the 2.97.38 romset havent converted over to the full 39
                                  BuZz administrators
                                  the retropie binaries for the rpi have now been updated to the latest version.
                                    juice
                                    @Darksavior hello mate is there an easy way to update this , i am running floob image retropie 4.1
                                    thanks
                                    FloobF 1 Reply Last reply Reply Quote 0
                                    • FloobF
                                      Floob @juice
                                      @juice You can update the binaries
                                      https://github.com/retropie/retropie-setup/wiki/Updating-RetroPie
                                      Obviously you should get the relevant romsets as well.
                                        juice
                                        thanks floob, i would like to say a big thanks for your image and videos, you made me a very happy man. i am a hyper spinner for years and the stress of setting that up was hidious and rewarding at the same time, this is so simple and on a pi3 aswell . will you be updating a new image in the future.
                                        ps one other question, i am having trouble with a few sega system 16 games, they have very scratchy sound (ie altered beast at the start when he say rise from your grave and in golden axe when you kill the 1st few the samples are scratchy and pitched to high). could you test these if you have time you confirm if this is the emulator or not i have tryed it on both fba next and mame2003. i have the correct romset
                                        thanks mate keep up the good work
                                        • DarksaviorD
                                          Darksavior @juice
                                          @juice
                                          Mame-2010 is the only emulator that'll run most of them with good sound. I use that with Altered Beast, Dynamite Dux, E-Swat, Golden Axe and Shinobi. Moonwalker runs way too slow on my PI2 so I have to use the old lr-mame4all for that one.
                                          • RionR
                                            Rion
                                            For those ho want to have more control over there rom collection
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, Arcade Only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, ColecoVision only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, Game Gear only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, Master System only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, Megadrive only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, MSX 1 Games only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, PC-Engine only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, Sega SG-1000 only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, SuprGrafx only)
                                            Dat File: FB Alpha v0.2.97.39 (ClrMame Pro XML, TurboGrafx16 only)
                                            Edit: @meleu
                                            Added
                                            FB Alpha v0.2.97.39 (ClrMame Pro XML) (NeoGeo Only)
                                            Rebuild using Non-merged-sets
                                            Place the roms in the neogeo roms folder and use FB Alpha v0.2.97.39 as the default emulator.
                                            Pre Configured config files with crt-pi-curvate shader & Final_Arcade_NeoGeo_Horizontal-bezel
                                            neogeo-crt-pi-curvature-Final_Arcade_NeoGeo_Horizontal-bezel-.zip.cfg
                                            Here is how its going to look when finished.
                                            SNK NeoGeo
                                            FBNeo rom filtering
                                            Fba Arcade Bezels
                                            Fba NeoGeo Bezels
                                            meleuM 1 Reply Last reply Reply Quote 3
