    Mame4All-Pi Controller Config D-Pad Problem
    mame4all-pi360 controllerps4 controller
    2 Posts 2 Posters 1.2k Views
    • O
      Obmug
      When mapping input in Mame4All-Pi, the d-pad down button doesn't register when pressed. I've tried both an Xbox 360 controller and a PS4. Both work fine in Retroarch, and jstest identifies d-pad down as button 16 for both controllers, but in Mame4All-Pi that button just doesn't register a press. I've tried taking a look at the cfg files, but they're apparently in a binary format I'm not sure what to do with. I've switched over to lr-imame4all for now, since Retroarch is working, but I'd like to solve this if anyone's got any suggestions.
      I'm running Retropie 4.0.2 on a RPi3, using that latest prebuilt SD card image. I've tried updating all packages from source. It doesn't appear to matter whether the controllers are connected via USB or onboard bluetooth.
        BuZz administrators @Obmug
        @Obmug If using a rpi3, you will do better to use lr-mame2003 as it's the most developed and supports more games.
