    Problem adding roms
    roms help
    4 Posts 2 Posters 1.3k Views
      snowy233
      Hi
      I'm using Sandisk ultra 64gb sd card , I've added roms thru USB flash drive and over wifi , the problem is getting past 10gb of roms and I've tried it 4 of these cards is after I've added 10gb of roms no more seem to work after that , the title shows up in consoles but when I click on a rom the screen goes back and then returns to the list of roms , for example the last ones I added was gba The first 400 work then everyone after that they dont , but every system I did before that all work , nes , snes , Atari , master system, fba, gb, gbc, sega32x, and lynx ,
      I can't understand how I can only add 10gb of roms on a 64gb card
      PleAse help , many thanks in advance
        snowy233
        Also to add I'm using retropie 4.0.2 and did format all 4 sd cards before I started
          BuZz administrators
          fake / faulty sdcards?
          bad PSU ?
          Incorrect roms ?
          Not sure what system you are running or how it is set up - you should read this - https://retropie.org.uk/forum/topic/3/read-this-first
          https://sosfakeflash.wordpress.com/2008/09/02/h2testw-14-gold-standard-in-detecting-usb-counterfeit-drives/
            snowy233
            Thanks for the reply , I'm thinking it could be fake sd cards. They was showing 64gb before I started ... I've remembered the first card I did was from a different shop and i had a full set of all roms , they all worked and even scraped them all , I've just found a 128gb generic sd card I'll see how I get on with this ,
            I've also tried this in a raspberry pi 2 and 3 so surely it must be the sd cards
