    UAE4Arm not working with my Xbox wireless controller
    uae4arm
    13 Posts 2 Posters 5.2k Views
      Shadowfax
      Hello,
      I have my Xbox360 Wireless controller working fine in ES and all other emualtors apart from UAE4Arm. I've gone to input and selected joypad which didn't work and then I tried the option Xbox wireless receiver and tried to map the U/D/L/R/Fire and nothing seems to work.
      Has anyone successfully used an Xbox wireless controller with UAE4Arm?
        a7mag3ddon
        I had issues with this emulator as well, go back to the 0.4 Binary and it should work, if you look on the GIT hub for that emulator you will see its been pointed out months ago to the developer.
          Shadowfax @a7mag3ddon
          @a7mag3ddon sorry for the silly question but how do I roll back to the 0.4 binary please?
            a7mag3ddon
            Juat download the 0.4 version and over write the one on your PI in the emulators folder.
              @a7mag3ddon so just download via windows and copy over via winscp?
                a7mag3ddon
                yeah thats what i did
                  Shadowfax
                  Hello,
                  Went to https://github.com/Chips-fr/uae4arm-rpi and downloaded uae4arm-rpi-master.zip from the top right corner, how do I know if this is version 0.4 or 0.5?
                    a7mag3ddon @Shadowfax
                    @Shadowfax seems its been removed, here you go https://drive.google.com/open?id=0B4272ME-kTRMbENHTmYyejV4dHc
                    copy into > /opt/retropie/emulators/uae4arm/
                    and over write the the one thats there
                      @a7mag3ddon thanks for the download, I have just renamed the current one to old and copied over yours and UAE4arm no longer runs, have I missed a step?
                        a7mag3ddon
                        check your permissions on the file, compare with the old one if not sure, i usually do mine as 777
                          Shadowfax
                          Permissions have helped thanks, but when I open then menu GUI is bigger that my monitor and I can't change it :)
                          Hopefully you can see from the image, by the way I have no idea why the screenshot is upside down here as it's fine on my onedrive site.
                            a7mag3ddon
                            cant help with that im afraid, doesnt do that on mine and i use preconfigured .uae files with WHDLoad for my Amiga ECS and AGA games.
                              Shadowfax
                              Right I have sorted the screen out (run command) and the controls now work on 0.4 so thanks.
                              What is strange though is UAE4Arm works on the Xbox analogue stick fine in all directions and the d-pad works but left doesn't work and I'm not sure where it get's this setting from. Any ideas?
