    PPSSPP Not Detecting 8BITDO FC30 Pro Gamepad
    troubleshootingppssppfc30 probluetooth
    5 Posts 3 Posters 2.9k Views
      AFoldedPage
      Pi Model: 3
      RetroPie Version Used: 4.1
      Built From: Pre made SD Image
      USB Devices connected: Keyboard, 2TB WD Portable HDD
      Controller used: 8BITDO FC30 PRO (Over Bluetooth)
      Error messages received: None
      Guide used: https://github.com/RetroPie/RetroPie-Setup/wiki/Setting-up-an-8bitdo-Bluetooth-controller
      Emulator: PPSSPP
      After following the guide above, my controller works fine with every Lib-Retro emulator I've used, but when I open up PPSSPP (I installed from source), plug in my keyboard and go to the controller tab in the settings to map my keys, It refuses to acknowledge the key presses of my controller.
      I would just use the default emulator, but last time I had this set up (I was using a Dualshock 4 at the time) the performance boost was worth it.
        BuZz administrators
        It may not be compatible. Which firmware are you running on the 8bitdo controller ? (do you have the 8bitdo hack on or off in the bluetooth settings ?)
          AFoldedPage
          I'm using 1.71, and have the 8bitdo hack turned off.
            AFoldedPage
            So, after a bit of frustration I've installed DS4DRV and am using a ps4 controller to play my psp games, which gave me an idea.
            The FC30 has an "extended" firmware which allows you to connect to devices such as the ps3 or wii. What do you think about installing that and setting it up as a ps3 controller? I'll try it out this weekend once my new laptop gets here.
              Muddyhardcore @AFoldedPage
              @afoldedpage
              Were you able to get the 8bitdo controller working?
              Pi 3, Retropie 4.2.7, 128GB SanDisk SD , CanaKit 5.1v Power Supply, 8bitdo NES30,
