    How-to Guide: Atari ST and STe Computing on the Raspberry Pi with RetroPie’s Hatari Emulator
    21 Posts 12 Posters 28.5k Views
      RetroResolution
      Hi all,
      Power Without the Price: Atari ST and STe Computing on the Raspberry Pi with RetroPie’s Hatari Emulator
      Great new RetroPie site and forum - I assume that user accounts were not carried over (either that or I mis-entered my credentials numerous times!)
      Having finally moved over to the fantastic RetroPie 3.6 release after getting a Pi 3 (my Pi 2 is running 2.x) I decided it was high time I wrote up a guide to running the Atari ST / STe emulator 'Hatari'. As this emulator does not incorporate the RetroArch core, it's not quite as plug-and-play as many of the other systems.
      Topics covered in the guide are as follows:
      [updated 29/4/2016] with sections for Atari ST / STe Specific Keys; Hatari Keyboard Shortcuts ; and Direct Loading Save States From Emulation Station]
      Emulation Without a Safety Net
      A Note on Emulation Legality
      Selecting RetroPie’s Hatari Emulator Version
      Initial Emulator Configuration
          System Menu
              Selecting Machine Type
              Settings Common to Atari ST and STe
              Settings for the Atari STe
          ROM Menu
              A Note on the Atari ST Bios
              Where Should the TOS Images Files be Placed?
          Memory Menu
              Memory Setup Options
              Memory Save State
          Atari Screen Menu
              Atari Monitor Options
              Extended VDI Screen Options
          Hatari Screen Menu
              Hatari Screen Options
              Screen Capture Options
              SDL2 Options
          Joystick Menu
          Keyboard Menu
          Sound Menu
          Loading Game and Other Software images
              The Floppy Disk Menu
              A Note Regarding Supported File Formats
          Hard Disks Menu
          Devices Setup Menu
      Saving the Configuration
      A Note on Using a Mouse
      External Links
      senkunS A 2 Replies Last reply Reply Quote 5
      • timeonmyhandsT
        timeonmyhands
        Very nice! I feel like a bit of a traitor given that I was the proud owner of a 520 ST and 1040 STE (with 2 meg of RAM!) - now I'm emulating Amiga games...
        senkunS 1 Reply Last reply Reply Quote 1
        • herb_fargusH
          herb_fargus administrators
          Very thorough!
          • senkunS
            senkun @timeonmyhands
            @timeonmyhands said;
            TRAITOR!1!
            ;P
            • senkunS
              senkun @RetroResolution
              @RetroResolution
              Thank you for this! Very much appreciated!
              • PingSpikeP
                PingSpike
                Props for this guide man!
                Here's my RetroStation project - http://www.pingspike.com/retrostation-part-4/
                :D
                  GrethTom
                  Amazing work their buddy, done quite a bit on Hatari myself. One thing I didn't see mentioned was launching straight into Save states which I have managed to do for all my games. Guide is on the Atari forum if interested/needed:
                  http://www.atari-forum.com/viewtopic.php?f=51&t=29605
                    RetroResolution @GrethTom
                    @GrethTom Thanks, that definitely sounds worth doing. I'll update my installation to get this running.
                    If you don't object I'd like to include your advice in the main guide (I'll probably mainly quote your information verbatim from the forum post you linked, citing you as the author)
                      RetroResolution @PingSpike
                      @PingSpike Thanks, that's great of you to say
                        RetroResolution @senkun
                        @senkun You're very welcome, great to hear that it's appreciated, makes it all worth while
                          RetroResolution @herb_fargus
                          @herb_fargus Cheers! I'm still tweaking and updating the guide as I find out additional useful information!
                            GrethTom @RetroResolution
                            @RetroResolution No problem at all buddy, feel free to use my info directly.
                              @GrethTom Thanks; I've just adjusted my system to load save states - works like a charm. I just tweaked things slightly to run in hatari compatible mode with borders - I run a lot of demoscene productions!
                              I'm updating the guide now.
                              Thanks again for the brilliant tip
                                RetroResolution
                                Three updates to the guide on 28/29th April:
                                Added sections for:
                                • Atari ST / STe Specific Keys
                                • Hatari Keyboard Shortcuts
                                • Direct Loading Save States From Emulation Station
                                  RetroResolution
                                  Another update to the guide on May 2nd:
                                  Hatari's in-built video capture
                                  I've now worked out how to resolve the AVI Recording : failed to open file error when trying to use Hatari's in-built video capture. The solution requires editing Retropie's emulator configuration entries.
                                  The updated guide covers the available codecs, editing the config, has some observations regarding codecs and impact on the emulator, amongst other items.
                                  Direct link to the updated section: Screen Capture Options
                                    Pyjamarama
                                    Ι opened up the hatari.cfg because I am trying to find a way to map F12 to my XBOX 360 pad (xboxdrv).
                                    Is that possible or I am fighting a loosing battle? :)
                                    If yes, how can I find the pad button codes?
                                    That is part of the Joystick0 part of hatari.cfg which works like a dream
                                    nKeyCodeUp = 1073741906
                                    nKeyCodeDown = 1073741905
                                    nKeyCodeLeft = 1073741904
                                    nKeyCodeRight = 1073741903
                                    nKeyCodeFire = 1073742052
                                    This is the part with the keyboard shortcuts
                                    [ShortcutsWithModifiers2]
                                    keyOptions = 111
                                    keyFullScreen = 102
                                    keyMouseMode = 109
                                    keyColdReset = 99
                                    keyWarmReset = 114
                                    keyScreenShot = 103
                                    keyBossKey = 105
                                    keyCursorEmu = 106
                                    keyFastForward = 120
                                    keyRecAnim = 97
                                    keyRecSound = 121
                                    keySound = 115
                                    keyPause = 0
                                    keyDebugger = 1073741896
                                    keyQuit = 113
                                    I want to find the 10 digit number to put in the keyQuit
                                    Thank you
                                      mediamogul Global Moderator @Pyjamarama
                                      @Pyjamarama said in How-to Guide: Atari ST and STe Computing on the Raspberry Pi with RetroPie’s Hatari Emulator:
                                      I am trying to find a way to map F12 to my XBOX 360 pad (xboxdrv)... I want to find the 10 digit number to put in the keyQuit.
                                      'keyQuit' is listed as being the SDL key code 113. Checking against the reference list here, you'll find it being the letter 'Q'. However, Hatari requires it's hotkeys to use the 'ALTGR' (or 'Right Alt') modifier. So, if you're looking to add that to an xboxdrv command, it would like:
                                      --ui-buttonmap back+start=KEY_RIGHTALT+KEY_Q
                                      Seeing as how 'back' normally stands in for 'select' in xboxdrv, this mapping keeps with the convention of using the 'start' and 'select' buttons together to exit a program like is seen in RetroArch, but you could also map to a single button as well.
                                      Edit: The SDL code for 'F12' can also be found on that reference link above and is 1073741893.
                                        sroweuk
                                        I've just tried to install Hatari but I cannot get it to run. I have the correct TOS but i cannot even get the Hatari config window to come up. I have set the emulator up to be "hatari-compatible", but when I check the runcommand.log file, it reports
                                        "Parameters:
                                        Executing: /opt/retropie/emulators/hatari/bin/hatari --confirm-quit 0 --statusbar 0 --zoom 1 -w --compatible 1 --timer-d 0 --borders 0 "/home/pi/RetroPie/roms/atarist/tos-2.06-uk.rom"
                                        /opt/retropie/emulators/hatari/bin/hatari: error while loading shared libraries: libcapsimage.so.5: cannot open shared object file: No such file or directory"
                                        I have tried both the binary install, as well as the source install. However, it does not appear to be copying the libcapsimage.so.5.1 file to my pi, as I cannot find it anywhere.
                                        I have also tried doing this manually; built the shared file and copied it to the Hatari install directory, but still receive the same error.
                                        Pi Model: 2 B
                                        RetroPie Version Used: 4.1
                                        USB Devices connected: WiFi Network, Wireless mouse, wired keyboard
                                        Controller used: none
                                        Error messages received: None on screen. Error in runcommand.log as above
                                        Log found in /dev/shm/runcommand.log (if relevant): as above
                                        Guide used: Power Without the Price: Atari ST and STe Computing on the Raspberry Pi with RetroPie’s Hatari Emulator
                                        File:
                                        Emulator: Hatari
                                        Attachment of config files:
                                        How to replicate the problem: As above
                                          Andreas77 @RetroResolution
                                          @RetroResolution
                                          This is great, thank you. I was having some issues before I read this.
                                          Cheers.
                                          • F
                                            fumanxu
                                            Hi
                                            I 'm strugling with the same problem. In my case is a retropie with a gpi case, which at the end, is like a raspberry connected to a xbox 360 controller (retropie identifies the controler within the case as x360). My problem is that I'm not able to create the initial configuration (to map buttons, select the tos image, etc) since I cannot connect a keyboard to launch F12.
                                            Please, could you give me details how you achieved to configure f12?
