    PS3 bluetooth connection problem with on board PI3 bluetooth
    ps3 bluetooth ppi3 model bbluetooth
    4 Posts 3 Posters 1.8k Views
      crazyazz
      Hi guys,
      I can get my original PS3 controller to pair to the PI3 with a bluetooth dongle but not with the onboard bluetooth. Running PI3 model B, with retropie 4.1
      Also what is this error ? Maybe its causing an issue
        crazyazz
        • I
          ibprofen98
          I've got the same problem. I just started a thread about it. I can connect my controllers with the cable, but they won't connect wirelessly, and I get that same error as you. :( can't seem to find an answer anywhere.
            BuZz administrators
            The error above happens I believe when the ps3controller driver is installed as the standard bluetooth daemon is disabled. The isue may be an update to the ps3controller driver which was in place for a day which had a bug. Try updating retropie-setup and removing/re-installing the ps3controller driver and repairing.
