    Retropie portable gpio controls problem.
    adafruitgpio
    10 Posts 5 Posters 2.2k Views
      giles2005
      Hi,
      Iv been working on a portable retropie using an adafruit 2.8 screen everything is working fine except the controls.
      Iv got some tact switches wired to the gpio as controls which work fine navigating the menus but once in an emulator the controls do nothing. Iv configured the controls under the emulation station menu which I thought set basic controls within each emulator so I'm a little confused.
      I'm pretty sure it's just something I'm doing wrong so any help would be greatly appreciated.
      • list item
      • rbakerR
        rbaker @giles2005
        @giles2005 Please provide more information:
        It's impossible to answer the "my project will not work, why?" question when it is asked alone.
          giles2005 @rbaker
          @rbaker said in Retropie portable gpio controls problem.:
          Thanks for the response a simple can you provide a bit more information about your setup would have been enough, no need to try make me out to be an idiot.
          BuZzB rbakerR 2 Replies Last reply Reply Quote 0
            BuZz administrators @giles2005
            @giles2005 the reply wasn't rude and seems perfectly reasonable to me - but sure, get on the defensive and see how that works out for you. (Or a better idea - please provide more information)
            Maybe if people actually read the sticky post which you have to "agree to read" on signup, we wouldn't have to go over this again and again.
              giles2005 @BuZz
              I had read through the sticky and I have searched for information before I got to this point. I thought I'd provided enough information to begin with I by no means expected an instant problem solve I was just getting the conversation started.
                How are you detecting GPIO inputs and converting them to key presses? What version of RetroPie are you running? What emulators are you using (not just the system)? That would be helpful.
                • rbakerR
                  rbaker @giles2005
                  @giles2005 said in Retropie portable gpio controls problem.:
                  I agree. That is why it is asked for here: https://retropie.org.uk/forum/topic/3/read-this-first
                  If you provide details of these controls people will look at them.
                  See "Attachment of config files: (PLEASE USE PASTEBIN.COM FOR LARGE LOGS)" in above link.
                  It's like asking for help with your essay but not providing a copy.
                  How?
                  Is it this, this or even this or something else entirely?
                  How you could think this if you had read https://retropie.org.uk/forum/topic/3/read-this-first
                  is beyond me. Imagine you were answering your own question but it wasn't written by you. Imagine trying to help out with issue. Ok, I'll take a look at the config first....nope.....ok, I'll check the wiring........nope. Ok, so lets look at which emulators don't work then......errr.....do you not get it?
                  I was not. However, you are welcome to think what you like, it's a free world.
                  list item
                  What is this? is this the bit where your post was incomplete by accident and that you did actually include more info but it never made it to the forum and you hadn't noticed?
                  Good Luck.
                    giles2005
                    ok well thanks for your help, sorry i didnt post in the correct fashion.
                    iv now solved the problem anyway. would have been nice to share the solution as a means to help others but nevermind.
                    markyh444M rbakerR 2 Replies Last reply Reply Quote -2
                    • markyh444M
                      markyh444 @giles2005
                      @giles2005 Bit childish of you that, dude. You do know this software is free and these guys do all the coding in their free time? I thought it was a reasonable request to ask for more info initially. You don't ring a garage and say my cars broken, and when they ask you what make, model and year it is you kick off and say you'll fix it yourself do you?
                      Retropie in a PSX - Pi3
                      • rbakerR
                        rbaker @giles2005
                        Before you share the solution to "the problem", you should tell us what "the problem" actually is!!?? You still have not done this. Currently, your problem is still "my project"does not work! Bizarre. I shall assume from your username that you were born back in 2005 and it shows.
