    PiSNES Load State Crashes Audio
    pisnesretropieaudio
    1 Posts 1 Posters 777 Views
      garakplainsimple
      Hi there, thanks for assembling such a tremendous resource. Having an issue where the audio goes nuts when trying to load save states...
      I am using the latest version of Retropie v4.1. I added the PiSNES core in order to be able to properly play Ken Griffey Jr. Presents Major League Baseball (the default emulators that came with retropie would not properly display the player data or allow season mode). I was able to successfully add PiSNES to emulation station and make it the default emulator for this particular rom.
      I am running into an issue where when I go to load a save state within PiSNES, it will crash the audio...for example I press Select+L on my controller, it will bring up the save state I previously created pressing select+R, the video is normal and everything still playable, however the audio sort of just hangs and gets stuck - think of a PC game crashing, how the sound would get stuck and be one long note of crash...sort of like if you played a game and got the blue screen of death...you know, that sound.
      Is there something I have to edit in PiSNES.cfg? I've searched extensively and I see others mentioning topics regarding pulse audio, or drive 2 or something or other...Thanks in advance!
