    Daphne help?
    50 Posts 13 Posters 45.7k Views
    • FinheadF
      Finhead
      Hey guys trying to get Daphne setup using this guide here.
      https://gameroomsolutions.com/setup-daphne-raspberry-pi-3-retropie/#comment-9764
      I am able to get as far as the emulator trying to open and giving me a error message. Anyone have an idea on what I am missing? I think I have the correct lair.zip file in the rom folder it's only 18kb like a mame rom though.
      • herb_fargusH
        herb_fargus administrators
        https://github.com/retropie/retropie-setup/wiki/Daphne
        http://blog.petrockblock.com/forums/topic/dragons-lair-space-ace-etc-anyone-interested-in-daphne-laserdisc-system/
        FinheadF 1 Reply Last reply Reply Quote 0
        • FinheadF
          Finhead @herb_fargus
          @herb_fargus
          Ok so I need to create another dirctory inside the daphne directory called roms as well? And then place this dle21.zip file into that directory? Where would I find that file? I can't seem it, have all the other files listed in the setup guide.
          roms
          |-- daphne
          | | (The folder below holds a laserdisc...".daphne"
          | | tells emulationstation to add this to the menu,
          | | and "dle21" tells daphne to use that game engine)
          | |-- dle21.daphne
          | | |-- dle21.commands (Optional extra command-
          | | | line params!)
          | | |-- dle21.txt (Framefile)
          | | |-- lair.m2v
          | | |-- lair.ogg <------------------------------------------------- I Have gotten whit far with all th correct files
          | | (All roms go into this roms folder)
          | +-- roms
          | +-- dle21.zip
          • herb_fargusH
            Well 18kb indicates your rom is not correct as the files for daphne range from 1-2 GB as daphne is a laserdisc emulator. Only way to get dragons lair is by purchasing a DVD which the daphneloader uses to verify ownership when then will download the files you'll need.
            You can see more info on Daphne's site and wiki: http://www.daphne-emu.com/site3/index_low.php
            • FinheadF
              Ah ok, that makes far more sense. So would this work of for getting it working on the pi? Sorry just like to buy what I need and not mess around buying something that won't work. Thanks for the help BTW. :)
              • herb_fargusH
                herb_fargus administrators @Finhead
                @Finhead I don't know if a CD ROM would work I think it has to be a DVD (it's possible I could be wrong): see this thread: https://www.daphne-emu.com:9443/phpBB3/viewtopic.php?t=2387 it might be worth verifying on the daphne forums just to make sure you don't spend money on something that doesn't work
                • FinheadF
                  Sorry wrong link, it is indeed a DVD box set that I found not CD-ROM. Thanks again for the info
                  • FinheadF
                    Finhead
                    So I got this working finally last night for the most part (still no controlles besides keyboard)
                    I have a glitch though, at least I think it's a glitch.
                    When you play the game and die it doesn't start at the level you were playing it actually advances to the next level. I'm pretty sure I remember DL starting you at the begining of the level you were at everytime.
                    I have the text log if that will help track this down? Also I had to put all my files in the one directory and not a second directroy like the wiki states, maybe that is throwing it off?
                    • caver01C
                      caver01
                      The original Dragons Lair rom doesn't keep restarting the same level. http://www.dragons-lair-project.com/games/related/sequence.asp
                      Some replay ability is available by playing the DLE21 rom.
                      Also, check the Daphne-emu site for lots of technical details.
                        twodollars
                        OK, I never really played this in the arcade way back when, so maybe it's because of that but it seems like I have Dargon's Lair working, but it's in incredibly hard mode all of the time. It seemed for a while that I could put a couple of coins in and then start a game but then it would advance through the game too quickly without giving me a chance for input. It took me a few tries but I figured out that it was giving me a chance to play, but that I needed Chuck Norris-level reflexes. Is there a ROM version or some command line tweaks that I should be using?
                        • caver01C
                          caver01 @twodollars
                          @twodollars You can definitely just play the lair.zip rom without changing any DIP switches in either bank, as this is what many folks remember seeing in the arcades when the game came out. Timing is everything with Dragon's Lair, and certain DIP switches change the difficulty, depending on the ROM. More important is memorization of the moves for each level. Levels can also be presented in right/left mirrored versions, so the moves you memorize have to be reversed. It's very easy to make a wrong move or to miss the correct timing. On some levels, wrong moves are fatal, but on other levels you can get away with it until you make the correct one.
                          Some like the lair_f rom, but over the years, Dragon's Lair Enhancement roms have been developed:
                          http://www.dragons-lair-project.com/tech/enhancements/dle21.asp
                          DLE21 is nice because it takes the existing video and essentially re-writes some of the logic that affects gameplay. That makes the game more intuitive in some respects and harder in others. For example, a level might look like you are supposed to move up but in the original game you had to move right--and because of the way the animation is drawn, it feels like a wrong move that works. In DLE21 some of these intuitions are "fixed". DLE21 also restores the drawbridge scene and allows some replay of failed levels before moving on to another level. In my mind, DLE21 is the way to go, but it's not historically what people remember.
                          Do a little research about Dragon's Lair dip switch settings and read all of the technical docs about the Daphne Emulator (not just what is written for RetroPie) and start playing with the command-line switches. The DIP switch banks can be configured to your liking such as the number of Dirks you get per credit, how the gameplay works, difficulty, etc. Just know that the DIP switches don't all do the same thing for all ROM versions. With the right command line switch, you can even introduce the video seek time lag that was present in the original game. I know, that's a distracting interruption of gameplay and it was a shortcoming of games that only had one laserdisc inside--but it faithfully reproduces the timing that you might remember if that's important.
                          • FinheadF
                            Finhead @caver01
                            DLE21 is nice because it takes the existing video and essentially re-writes some the logic that affects gameplay.
                            Curious how do you use the DLE21.zip file? I bought the DVD pack and have all the files but that .zip doesn't seem to work.
                            • caver01C
                              caver01
                              Consider the way it works when you are successful. I expect you are running the lair.zip. If you have the folder structure setup correctly, when you select lair, it's looking for the lair.daphne folder, and inside that, it requires each of the framefile components (the lair.txt, the .ogg, the .m2v). Got it? Also, the lair.txt file is basically just a reference to the media files listing the frame offsets.
                              Now, when you want to try DLE21 you need to have the dle21.zip file in your roms folder (so you can pick that one in Emulation Station), and it needs a corresponding dle21.daphne folder, and inside that, a dle21.txt framefile and so on.
                              The best way to think about it is that you need a COMPLETE DUPLICATE of everything you have setup with "lair" to be setup with "dle21". This will work but it will also result in a big waste of space because you end up with a copy of the .m2v files. You can avoid that step, but you still need to build out the folder structure, and you definitely need a dle21.txt for it to work. Here's the space-saving trick: Inside the dle21.txt you want to edit it to point to the media files in the lair.daphne folder. The first line of the txt file tells daphne where to look for the files referenced. Usually, it's just a dot: "." to indicate that the media files are right here next to the .txt file. However, you could start off your dle21.txt file with "../lair.daphne/" basically telling the emulator to go up one directory, then down into lair.daphne for the media files. The rest of the .txt references the components and frames just like the lair.txt file does.
                              This allows you to share the media files among ROMs for the same game by simply replicating the folder structure, but pointing to one single folder with the video/audio.
                              Sorry if this is confusing, but this is the best way to do it while keeping the names of the ROMs correct.
                              Another way to go is to open the lair.zip file and replace the contents with files from the DLE21 ROM (or simply rename the ROM zip files). I don't like this approach because then lair.zip is not actually the true lair.zip anymore, and you need to know what you did to change it. Worse, ROMs behave differently with respect to DIP switches you may have specified in a command file. My approach allows you to build out the folder structure for various ROMs, and this allows you to have independent command files (like lair.command, dle21.command, etc.).
                              • FinheadF
                                Finhead @caver01
                                Yes I have a proper working directory for the Dragon's Lair DVD which is the standard (lair.txt, the .ogg, the .m2v) and it works perfectly fine.
                                What I'm asking is how to get the Enhanced version to work since all I can find is the DLE21.zip file, there is no other files I can find in the Daphne downloader or the site you linked. There simply isn't any of the needed files to make another folder, so I guess I'm asking where does one locate the lair.txt, the .ogg, the .m2v for that version.
                                • caver01C
                                  caver01 @Finhead
                                  @Finhead It uses the same media. In the real world, it uses the same laserdisc. You don't find files because they are not needed. You just copy the existing, or in my long description above, you avoid the copying and simply reference the ones you already have for lair.
                                  • caver01C
                                    caver01 @caver01
                                    in other words, create a dle21.daphne folder. inside that, create a dle21.txt file (make a copy of the lair.txt file). Put it in the dle21.daphne folder and name it dle21.txt. Copy the .m2v and the .ogg and the .dat. Put them into the dle21.daphne folder.
                                    You see? You are simply using the lair media to run the DLE21 ROM. Then, save a bunch of space by editing the dle21.txt to point to the lair folder and get rid of the duplicate .m2v and .ogg and .dat. They are not needed if you point to the files in lair.daphne.
                                    • FinheadF
                                      Finhead @caver01
                                      Ah yes that does indeed work, not sure why I thought there would be other files.
                                      Thank you very much for the help on that. :)
                                      • RiverstormR
                                        Riverstorm
                                        I'm not sure if I can piggyback here for help with Daphne. I was running the install script and my Pi locked up. I did a reboot and started it again. It completed successfully the second time and I see the roms folder and the config folder but there's no menu option after populating the roms folder and restarting the Emulationstation/Pi. Did the crash mess something up or am I missing something to run Daphne?
                                        In the Logs I am seeing a lot of "No such file or directory". I am running 3.7, updated the script and reinstalled. It seems to run to completion.
                                        Configuring 'daphne' : Daphne - Laserdisc Emulator
                                        /opt/retropie/supplementary/emulationstation
                                        Log ended at: Thu Apr 21 13:09:59 CDT 2016
                                        Total running time: 0 hours, 4 mins, 58 secs
                                        Log errors:
                                        make[1]: Entering directory '/home/pi/RetroPie-Setup/tmp/build/daphne/src/ldp-out'
                                        Makefile:15: sony.d: No such file or directory
                                        Makefile:15: pioneer.d: No such file or directory
                                        Makefile:15: ld-v6000.d: No such file or directory
                                        Makefile:15: hitachi.d: No such file or directory
                                        Makefile:15: philips.d: No such file or directory
                                        Makefile:15: ldp.d: No such file or directory
                                        Makefile:15: framemod.d: No such file or directory
                                        Makefile:15: ldp-combo.d: No such file or directory
                                        Makefile:15: ldp-vldp.d: No such file or directory
                                        Makefile:15: ldp-vldp-audio.d: No such file or directory
                                        Makefile:15: ldp-vldp-gl.d: No such file or directory
                                        Makefile:15: ldp-vldp-gp2x.d: No such file or directory
                                        make[1]: Entering directory '/home/pi/RetroPie-Setup/tmp/build/daphne/src/cpu'
                                        Makefile:15: cpu.d: No such file or directory
                                        Makefile:15: mamewrap.d: No such file or directory
                                        Makefile:15: cpu-debug.d: No such file or directory
                                        Makefile:15: m80.d: No such file or directory
                                        Makefile:15: mc6809.d: No such file or directory
                                        Makefile:15: 6809infc.d: No such file or directory
                                        Makefile:15: nes6502.d: No such file or directory
                                        Makefile:15: nes_6502.d: No such file or directory
                                        Makefile:15: cop.d: No such file or directory
                                        Makefile:15: copintf.d: No such file or directory
                                        make[1]: Entering directory '/home/pi/RetroPie-Setup/tmp/build/daphne/src/io'
                                        Makefile:16: input.d: No such file or directory
                                        Makefile:16: serial.d: No such file or directory
                                        Makefile:16: conout.d: No such file or directory
                                        Makefile:16: cmdline.d: No such file or directory
                                        Makefile:16: conin.d: No such file or directory
                                        Makefile:16: parallel.d: No such file or directory
                                        Makefile:16: error.d: No such file or directory
                                        Makefile:16: network.d: No such file or directory
                                        Makefile:16: sram.d: No such file or directory
                                        Makefile:16: fileparse.d: No such file or directory
                                        Makefile:16: unzip.d: No such file or directory
                                        Makefile:16: mpo_fileio.d: No such file or directory
                                        Makefile:16: numstr.d: No such file or directory
                                        Makefile:16: homedir.d: No such file or directory
                                        Makefile:16: logger.d: No such file or directory
                                        Makefile:16: logger_console.d: No such file or directory
                                        Makefile:16: logger_factory.d: No such file or directory
                                        make[1]: Entering directory '/home/pi/RetroPie-Setup/tmp/build/daphne/src/game'
                                        Makefile:18: game.d: No such file or directory
                                        Makefile:18: boardinfo.d: No such file or directory
                                        Makefile:18: lair.d: No such file or directory
                                        Makefile:18: superd.d: No such file or directory
                                        Makefile:18: thayers.d: No such file or directory
                                        Makefile:18: astron.d: No such file or directory
                                        Makefile:18: firefox.d: No such file or directory
                                        Makefile:18: cliff.d: No such file or directory
                                        Makefile:18: speedtest.d: No such file or directory
                                        Makefile:18: seektest.d: No such file or directory
                                        Makefile:18: cputest.d: No such file or directory
                                        Makefile:18: ffr.d: No such file or directory
                                        Makefile:18: esh.d: No such file or directory
                                        Makefile:18: laireuro.d: No such file or directory
                                        Makefile:18: badlands.d: No such file or directory
                                        Makefile:18: starrider.d: No such file or directory
                                        Makefile:18: bega.d: No such file or directory
                                        Makefile:18: multicputest.d: No such file or directory
                                        Makefile:18: cobraconv.d: No such file or directory
                                        Makefile:18: gpworld.d: No such file or directory
                                        Makefile:18: interstellar.d: No such file or directory
                                        Makefile:18: benchmark.d: No such file or directory
                                        Makefile:18: lair2.d: No such file or directory
                                        Makefile:18: mach3.d: No such file or directory
                                        Makefile:18: lgp.d: No such file or directory
                                        Makefile:18: timetrav.d: No such file or directory
                                        Makefile:18: releasetest.d: No such file or directory
                                        Makefile:18: singe.d: No such file or directory
                                        Makefile:18: test_sb.d: No such file or directory
                                        • FinheadF
                                          Finhead @Riverstorm
                                          @Riverstorm said in Daphne help?:
                                          You have to setup Daphne a little different then the other emulators.
                                          Here is how you have to structure your ROMS dirctory
                                          You will also need the files from Daphne Downloader to place in the directory as shown. You will need to own a copy of the DVD for Dragon's Lair, Dragon's Lair 2 and Space Ace for the downloader to grab the files you need. It needs to verify this before hand.
                                          • RiverstormR
                                            Riverstorm @Finhead
                                            @Finhead said in Daphne help?:
                                            Thanks Fin, I didn't give you all the information. Sorry, I did use that page for my directory layout. I do have the directory structure in place and the files in the correct directories. What I mean is the main screen, not the in emulator detail view but I mean I don't have the Daphne emulator to choose as an option at the main screen if that makes sense. If I look at es_systems.cfg it doesn't have the Daphne emulator in the file.
                                            So I reran /RetroPie-Setup/retropie_setup.sh, choose Experimental packages and 106 daphne. It looks like it completes ok except those errors I pointed out above. I did run it more than once, after a warm reboot, cold reboot to test the insanity theory but still no luck yet. I tried running it from the command line in /opt/retropie/emulators/dahpne/ but it fails because of my parameter syntax is incorrect. I just don't have it as a menu option to test it all out.
                                            I see the directories look intact and fine:
                                            /opt/retropie/configs/dahpne/
                                            /home/pi/RetroPie/roms/daphne
                                            I did download the zip from Daphne Downloader and put the files under /opt/retropie/emulators/daphne/
                                            This is my structure under /home/pi/RetroPie/roms/:
                                            daphne
                                            |-- dle21.daphne
                                            +-- dle21.txt, *.m2v, *.ogg
                                            |--roms
                                            +-- dle21.zip
