    Problem with second controller always being player 1 in retropie menus, jstest...
    controller 1jstestretropie menu
    1 Posts 1 Posters 775 Views
      edmaul69
      First off i am on retropie 4.1 or 4.01. I forget which cause i updated my setup script. Latest update i did was yesterday on it. So i have an issue. I can set which controller is player 1 and two by usb order. However, no matter which order i put my controllers, the jstest, retropie menus and wolf4sdl see my 2600-daptor II as player 1. If i hot swap them then they are correct but i cant open my apple iie everytime i power on to swap the controllers. Emulationstation sees player 1 and 2 correctly. If i have my apple iie keyboard plugged in it is seen as the first joystick for retropie menus. I cant test it in wolf4sdl because I am waiting on a new chip to arrive for my keyboard because it was defective, so i cant test it right now. Is there any way to fix this? It wouldnt bother me except for the wolfenstein games dont work on the correct controller. I have done the raphnet northwest joystick patch so i hope that isnt an issue but i believe this was an issue before then.
