    Streets of rage remake help "esc" key needed
    button mappingportssorrcontrol configmain menu
    24 Posts 4 Posters 9.0k Views
      trixta
      no I never got this working :( and gave up on it
      • hansolo77H
        hansolo77
        Honestly, if you have a few hours to spend figuring it out.. XBOXDRV is the best way to make this work. I now have it working over here, and have a dedicated button (BACK) to use as the escape key. Just takes a little bit of research and patience. I'm glad I had a free weekend to work it out. This game is awesome!
        Who's Scruffy Looking?
          trixta @hansolo77
          @hansolo77 said in Streets of rage remake help "esc" key needed:
          care to share the files?
          • hansolo77H
            hansolo77
            I posted the working configs in my process thread here:
            https://retropie.org.uk/forum/post/46824
            But honestly, you'll benefit from doing the work yourself too. One of the things in particular is that the controller I'm using (Wireless Xbox360) is mapped on my device as Joystick #5, and Event #7. If you only have 1 controller, yours may be listed as something like Joystick #0 and Event #1 or something. Also, it looks like it's picking up a serial number or something in the actual device name, so it might not work at all. But you're more than welcome to give it a try, maybe you'll get lucky. Also, I'm using the default keyboard mapping in the game, so if you've changed it, you'll want to reset it.
            I just double checked, and it doesn't look like the the port assignment is needed for anything more than identifying the actual button maps. The configuration uses by-id so it'll work no matter what port or joystick # it's assigned to. The only issues you'd have would be if the controller you're using ISN'T the same, and if the ID is incorporating a serial number.
