    Weird Controller Problems (yes, again)
    controllersxbox360nesraphnet
    53 Posts 5 Posters 18.2k Views
      @hansolo77 please, wait a little before going on this trick. I noticed that it doesn't work after some changes that runcommand got recently. I've already reported here.
      hansolo77H 1 Reply Last reply Reply Quote 0
      • hansolo77H
        hansolo77
        It's still not working. I don't know what's going on. Here's everything I did:
        Connect the NES controller adapter to USB, Connect Xbox dongle to USB
        sudo visudo
        Added a 4th Defaults line (with a tab in beween): Defaults env_keep += "__joy2key_dev"
        CTRL+X -> Y -> ENTER (saves file as /etc/sudoers.tmp)
        sudo nano /etc/environment
        Added a new line: __joy2key_dev="/dev/input/js2"
        CTRL+X -> Y -> ENTER (saves file as **/etc/environment)
        sudo reboot
        (wait for system to load up ES)
        Select Atari 2600 (first system on line)
        Select 3D TicTacToe (first game)
        Run-Command displays, I press ALL BUTTONS on the Xbox controller, nothing happens
        Game Starts
        Also doing all this, with js0 and having the NES adapter does nothing.
        The only way I can get it to detect key presses on Run-Command is to have everything # commented out on those 2 files, and have the NES adapter unplugged. Without having them # commented out, while having the NES adapter unplugged does nothing. So clearly it's doing SOMETHING. Maybe Run-Command isn't right?
        • Both controller adapters connected to USB = Only NES Works
        • NES adapter connected, Xbox not = NES Works
        • Xbox adapter connected, NES not = Xbox Works
        • Modified variable entries, both controllers connected = Nothing Works
        • Modified variable entries, NES connected, Xbox Not = Nothing Works
        • Modified variable entries, Xbox connected, NES Not = Nothing Works
        So the key presses just plain don't work when adding the new variable lines. Without them, they work fine by themselves, or only the NES one works when both connected.
        Who's Scruffy Looking?
        • hansolo77H
          hansolo77 @meleu
          @meleu said in Weird Controller Problems (yes, again):
          @hansolo77 please, wait a little before going on this trick. I noticed that it doesn't work after some changes that runcommand got recently. I already reported here.
          Ah OK. I didn't refresh my page before typing up my latest reply. Since everything works ok using just the Xbox controller and no modified files, I'll just keep it like this until something else comes up to try. I'll probably post back tomorrow/etc to see if there's anything new.
          Looking at the changes, all we need to do is change the variable to ALL CAPS and remove the preceeding __ right? But if it was just changed in the file, the changes need made on those other files as well. Maybe I'll still just wait.
          • hansolo77H
            hansolo77 @meleu
            @hansolo77
            The __joy2key_dev is used only by the scripts which call joy2key.py. If you are curious, here are links to the exact line in each file:
            • runcommand.sh
            • helpers.sh (used by retropie_setup.sh)
            • jsfuncs.sh (used by RetroPie-joystick-selection tool)
            I'm away from my raspi now, but I'll try to find a solution when I get home. And the first thing I'll try is to put that export line at the end of /etc/profile. :-)
            Should I try going through my system and replace all __joy2key_dev entries in the above listed files to just JOY2KEY_DEV and then also change the calls in the /etc/environment and sudoers files? Do you think that might work? I'm trying to rescrape my library right now (taking forever for some strange reason) but I'll make an SD card backup before I try it.
              meleu @hansolo77
              @hansolo77 I think it'll work, but my suggestion is to wait for the "official" solution. The decision made for runcommand.sh and helpers.sh I'll put on the jsfuncs.sh.
              • hansolo77H
                hansolo77
                Will do! Thanks for all your help.
                  meleu @hansolo77
                  @hansolo77 you can update your retropie_setup and then the runcommand.
                  I think the trick will work now. ;-)
                  • hansolo77H
                    hansolo77
                    I'm still scraping metadata, so I won't be able to try this till I get home from work tomorrow. But I'd just like to clarify... I don't need to do anything like my suggestion of going through the various scripts and updating them all to JOY2KEY_DEV right? I just need to run the Update RetroPie-Setup Script and it should take care of it all? Obviously I'll need to un-comment out the lines I added to /etc/environment and visudo right?
                      meleu @hansolo77
                      @hansolo77
                      1. Update RetroPie-Setup Script.
                      2. Update runcommand (Manage packages -> core -> runcommand -> Update from binary).
                      3. add __joy2key_dev="/dev/input/js2" to /etc/environment file.
                      4. add Defaults env_keep += "__joy2key_dev" to your /etc/sudoers (use sudo visudo command to edit this file).
                      5. reboot.
                      I hope I didn't forget any step this time. :-)
                      • hansolo77H
                        hansolo77
                        Ok so we're going back to the lowercase and the __ bits. I'll try that tomorrow!
                        • hansolo77H
                          hansolo77
                          IT WORKS!!! haha OMG it works lol. Thank you so much for figuring this out for me. Looks like the functionality was always there, just broken over the course of time. Things like the ALL CAPS, and the loss of system-wide variables (needing to be SU). Now all I have to do is figure out how to make the Joystick-Selector work, but this is a NEXT step, and not related to this thread anymore. Consider this 'bug' smashed!
                          Thanks so much!
                            meleu @hansolo77
                            @hansolo77 said in Weird Controller Problems (yes, again):
                            Do you mean it isn't working? I would like to know what is going wrong. Could you open another thread detailing you problem?
                            • hansolo77H
                              hansolo77
                              No, I just meant I haven't tried to tackle setting it up yet. I will definitely open a new thread if I have issues. :) Thanks again!
