    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 889.1k Views
    • FlyingTomahawkF
      FlyingTomahawk @mattrixk
      @mattrixk
      I knew that it is possible to create mix profiles I just didn't know how to add the video part.
      I wanted to take the Standard 2img profile and just replace the screenshot code with the video code.
      You provided your code which will help me do that. Thanks.
      mattrixkM 2 Replies Last reply Reply Quote 0
      • mattrixkM
        mattrixk @FlyingTomahawk
        @FlyingTomahawk:
        This Scrape Profile should do what you want it to do.
        Just add it to the "ProfilsFiles" folder within UXS, then select it from the Scrape Profiles list. You'll also need to set up the autoconfig so UXS sees your Roms, and points the paths where they need to go. You'll then need to select the Standard (2img) MIX Profile and you should be good to go.
        FlyingTomahawkF 1 Reply Last reply Reply Quote 1
        • FlyingTomahawkF
          @mattrixk
          Awesome! Thx.
          I test it as soon I get back from work.
          • mattrixkM
            @FlyingTomahawk I had to update that xml file as it still had some unneeded parts in it, but it's fixed now.
            FlyingTomahawkF 1 Reply Last reply Reply Quote 0
            • FlyingTomahawkF
              @mattrixk
              I had a chance to test the code of yours and it does give me the correct entries inside the gamelist xml file but the videos are downloaded as "gamename"-video.png
              I can see that the entry for video in your file is correct and says mp4 as file format but I think the Standard (2img) code is saying to save it as png. I tried to change that to match a video file and mp4 format but then I get all kinds of errors.
              Right now I am scraping the roms twice, once for marquee and once for video. At the same time I set it to update the XML file to get the right entries.
              That works good for me right now, I just thought I could reduce 1 scraping step and have both at once.
              E mattrixkM 2 Replies Last reply Reply Quote 0
              • E
                EctoOne @FlyingTomahawk
                @FlyingTomahawk Can you not just batch rename the *-video.png files? I'm using a similar scrape profil as @mattrixk has and it also downloads the video files as png. My script downloads all files (2D Box, marquee, screenshot, fanart, video), creates a Mix Image but only put the mix image in the xml (because i don't care about video, but i want to have the other images). So that's why i deleted all my *-video.png files after scraping without testing if those where just falsly named mp4 files.
                • FlyingTomahawkF
                  FlyingTomahawk @EctoOne
                  @EctoOne
                  Yes, I did that. I batch renamed them and I can do that for all the others too.
                  Still it does not reduce my work, I still need to do 2 steps either scraping, scraping or scraping, renaming.
                  But then again I don't think I will be doing a lot scraping once everything is setup, so a 2 step solution is not bad after all.
                  • E
                    @FlyingTomahawk
                    OH right, I forgot that you have to edit the xml files as well if you rename the files. I probably purged the memory from my brain about all the work I had with my setup. :D
                    • mattrixkM
                      @FlyingTomahawk that's really odd. I didn't have a problem scraping videos, but I don't think I used that exact profile (I have lots of them scattered around my hard drive in various states of completion).
                      I'll hopefully get a chance to have a look at it tomorrow.
                      • mattrixkM
                        @FlyingTomahawk okay, I just had a quick look and this is what it should scrape:
                        <image>gamename-screenshot.jpg</image>
                        <marquee>gamename-mix-video.png</marquee>
                        <video>gamename-video.mp4</video>
                        Are you maybe getting confused about the MIX image being called "-mix-video.png"?
                        • FlyingTomahawkF
                          @mattrixk
                          hmm...nope not confused....I think.
                          I had the video files as png format and when I renamed them to mp4 all was good.
                          I am fiddling for 3 hours now and at the same time cleaning out my roms since I try to reduce it to max 50 roms per system. Let's be honest no one really needs 700+ roms per system, there is no way to play all the games anyway. That will reduce my work with this video stuff significantly.
                          So I might have a burnout at the moment and lost a bit overview and concentration.
                          • E
                            @FlyingTomahawk
                            Tell me about it. I probably spend a whole week just to get perfect Metadata. At the very beginning I've made the decision to use the standard 3 img mix, but I changed it to use 2D boxart. So I was able to simply create/fix images if they had missing elements or none at all (for Romhacks). Then go through the created xml with the Metadata Editor to check if everything is set correctly. It was such a tedious task, I won't even imagine to do that with complete romsets.
                            • mattrixkM
                              @FlyingTomahawk okay, that's really strange and I have no idea why that's happening. I'll have to do some testing.
                              • FlyingTomahawkF
                                @mattrixk
                                Yesterday before I called it a day I reverted everything. I deleted the UXMLS files and downloaded a fresh package from github.
                                Now I don't know what is going on but I have the following issues now.
                                1.)
                                No matter if I choose RetroPie mix profile or regular RetroPie when I scrape now and select create new XML file as option it scrapes 3 images.
                                Marquee, video.png and screenshot.
                                Looking at the XML file there I have the right paths but at the end many empty </game> tags.
                                1. )
                                  If I select "update XML file" in the options he doesn't scrape anything. 0/0 roms.
                                3.)
                                Previously I could download only videos or only images without creating an XML file by selecting "create image only" in the options.
                                When I do that and I select video it creates the videos in png format and also the regular screenshot images.
                                I have no idea why this all is happening. I mean I deleted everything from my PC, restarted it, downloaded a fresh, new UXMLS package from github. Still it won't go back to normal.
                                I will take another look at it today but this is getting annoying.
                                • FlyingTomahawkF
                                  FlyingTomahawk
                                  So back at it again...new day, new luck?
                                  Can someone please give the following a try and tell me what they get?
                                  Load RatroPie MIX [Rom folder]
                                  Select Standard (2img)
                                  Settings in General options
                                  Create New XML file
                                  Picture configuration
                                  default
                                  Options configuration
                                  Item Choice
                                  Marquee
                                  Paramater to change
                                  Wheels
                                  What files do you get and what file extensions do you see in the game list?
                                  Create New XML file
                                  default
                                  Item Choice
                                  Video
                                  Paramater to change
                                  Yes
                                  • mattrixkM
                                    @FlyingTomahawk hmm, very strange. Do things scrape correctly if you just use the built-in profiles? The latest version of UXS is v6, so if you're still having problems with that one, you could try v5 or v4. I don't think I'll have a chance to do any testing today (niece's b'day then mate's going away party), but I'll hopefully have a chance tomorrow.
                                    • FlyingTomahawkF
                                      @mattrixk
                                      That's the first thing I did this morning. I tested the Standard (2img ) and all was good. Correct images with correct file extension and correct gamelist entries.
                                      I want to scrape that game logo image (wheel? ) only that you can see bottom-right on the Standard 2 and 3img profile.
                                      And only the video.
                                      So 2x scraping total.
                                      Just enjoy your day/weekend, please don't mind me. I will figure it out one way or the other, just a matter of time.
                                      • mattrixkM
                                        @FlyingTomahawk no worries mate, we'll get this worked out (eventually).
                                          Dochartaigh
                                          I swore this was already gone over, but you can't search this entire thread (keeps on loading only sections at a time).... I'm having an issue where scraping Playstation adds a gamelist entry for every single file a certain PS1 game will have (some have just a .BIN and a .CUE - others have like 30 .BIN's and a single .CUE - so that one would have 31 files listed in the gamelist). How to fix?
                                            Jeck11 @Dochartaigh
                                            @Dochartaigh add an exclusion for *.bin and you shouldn't get doubles.
                                            Also, to search a specific thread on this site just click in the thread the hit ctrl-f. You should see something like thread:678533 show up in the search box.
