    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 890.9k Views
    • Y
      yortdog
      @paradadf : Not sure, but logged in this morning & it's working fine. Perhaps a localized network connection problem. I can see the text file now.
      Sorry for the false alarm. The Universal_XML_Scraper64.exe program loads fine for me today.
      • SuperMagicomS
        SuperMagicom @paradadf
        @paradadf The file was not there when he posted it. I checked it myself.
        • SuperMagicomS
          SuperMagicom
          Latest version still is not creating mix profiles properly. The 2.2 versions have been major downgrades both in GUI usability and stability.
            Dochartaigh @SuperMagicom
            @SuperMagicom said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
            @screech Latest versions, including today's update, throwing "AutoIt error: Subscript used on non-accessible variable" and crashing after boot screen. 2.1.0.4 is the newest version that will run normally. :(
            Same "subscript used on non-accessible variable" error for me as well. Actually went back to the old non-updated version since the new version seems to crash more than the old...
            SuperMagicomS 1 Reply Last reply Reply Quote 0
            • SuperMagicomS
              SuperMagicom @Dochartaigh
              @Dochartaigh I noticed that the new versions tend to miss a lot of roms that the old version does not. They're also slower and the interface has also become unnecessarily complicated (settings buried in submenus). I'm sticking with 2.1.0.4 for the foreseeable future.
              • AnalogHeroA
                AnalogHero
                I really like this tool. It works almost perfect, altough it seems it has issues with some characters in filnames.
                When i look at the missing txt in my snes folder it has not scraped any roms with " ' " in it.
                I dont think its possible but it would be great if this tool would work on the pi itself from emulationstation. But im dreaming here ofcourse...
                • denisuuD
                  denisuu
                  In the new version it seems to have moved the pictures and the XML file to a different location. How can I move them to the game folder again?
                  Configuration > advanced > Auto configuration Path configuration
                  Then what do I change the paths to, to make it like it was in previous versions?
                  • screechS
                    screech
                    @denisuu
                    Try this :
                    In ProfilsFiles Folder, open Retropie.xml
                    Look for the section <AutoConf>
                    and replace it by :
                    <AutoConf>
                    <Source_RootPath>\\retropie\roms</Source_RootPath>
                    <Target_XMLName>%Source_RootPath%\%system%\gamelist.xml</Target_XMLName>
                    <Target_RomPath>./</Target_RomPath>
                    <Source_ImagePath>%Source_RootPath%\%system%\downloaded_images</Source_ImagePath>
                    <Target_ImagePath>./downloaded_images/</Target_ImagePath>
                    </AutoConf>
                      rapidfire
                      i dont know if this topic is still active or not, but ive got several problems with the xml scraper
                      • it keeps downloading corrupt or empty .PNG files.
                        these corrupt files slow down emulation station to a crawl and when you quit emulation station you can see a screen full of error messages about wrong dimensions in png files.
                      • it keeps naming some of the roms in gamelist.xml as "(CLONE, PROTO, HACK ... etc.
                      when i first downloaded the scraper it worked perfectly on all games and gave nice results.
                      now its doing this
                      im using V2.2.0.1
                      retropie v4.2
                      a pi3 b
                      • mattrixkM
                        mattrixk @rapidfire
                        @rapidfire What Scrape/Mix Profiles are you using? Have you started using different ones recently? Are they the ones built into the system, have you made your own, or are you using the ones from the ES Toolkit?
                        mattrixkM R 2 Replies Last reply Reply Quote 0
                        • mattrixkM
                          mattrixk @mattrixk
                          @screech: I'm using v2.1.0.6 and I've been scraping stuff without a problem for the last couple of days, but I just got this error while scraping PC Engine:
                          Imgur
                          I haven't made any changed to the scraper or the Profiles used. The scraper made it 153 entries into a total of 234 items.
                          This is the end of the log file: Pastebin.
                          It seems to have borked at "Power Eleven". When I clicked "OK" on the error box, the program continued scraping the rest of the files, but it skipped the next 8 files after "Power Eleven".
                          It seemed to scrape the rest of the files without issue.
                            rapidfire @mattrixk
                            @mattrixk said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                            i use the 2img profil
                            i was using 4img and arcade-zoomed-moon-retropie previously, but changed to 2img because i just wanted a screenshot and not much else
                            i see from another post you are using 2.2.0.6. where do i download that version from? i went to github and it only has 2.2.0.1.
                            ive never used estoolkit (didnt even know it was a thing until you mentioned it)
                            • mattrixkM
                              mattrixk @rapidfire
                              @rapidfire I'm using the 2106 version, not the 2206 version. I haven't really tried any of the 2.2 versions yet because they're a pretty big change from v2.1, and 2.1.0.6 does what I need it to.
                              I put together the Toolkit (with the help of Herb Fargus) so people could easily get started with making themes.
                                rapidfire
                                follow up to my problem.
                                just tried it again using only the visual option (not mix)
                                fba, and nes all give gamelist.xml similar to this (this is a small section from the fba gamelist)
                                zx spectrum downloads no images whatsoever. i know they exist on screenscrapers because sselphs scraper grabs them.
                                <gameList>
                                <game id="" source="ScreenScraper">
                                <path>/home/pi/RetroPie/roms/fba/1941.zip</path>
                                <name> (Clone, Beta, Demo, Proto, Trad, Hack, Unl)</name>
                                <desc/>
                                <image/>
                                <image/>
                                <marquee/>
                                <video/>
                                <thumbnail/>
                                <rating>0</rating>
                                <releasedate>00000000T000000</releasedate>
                                <developer/>
                                <publisher/>
                                <genre/>
                                <players/>
                                </game>
                                <path>/home/pi/RetroPie/roms/fba/1942.zip</path>
                                <desc/>
                                <image/>
                                <image/>
                                <marquee/>
                                <video/>
                                <thumbnail/>
                                <rating>0</rating>
                                <developer/>
                                <publisher/>
                                <genre/>
                                <players/>
                                </game>
                                • mattrixkM
                                  mattrixk
                                  @screech: I've been using the same copy of 2106 on my work computer for a while now, but today I just started getting this error when I try to open the program:
                                  Imgur
                                  I get this error with the following versions: 2105, 2106, 2201.
                                  When I first run the program, this is what the log says:
                                  [12:34:53] - C:\MattK\UXS\Universal_XML_Scraper64.exe (2.1.0.6)
                                  [12:34:53] - WIN_7(X64) - 0409
                                  [12:34:53] - Scrape in x64
                                  [12:34:53] - Starting files installation
                                  [12:34:56] - Error Downloading URL : https://raw.githubusercontent.com/Universal-Rom-Tools/Universal-XML-Scraper/master/Ressources/ServerList.txt
                                  Then when I try to run it again it says this:
                                  [12:35:21] - C:\MattK\UXS\Universal_XML_Scraper64.exe (2.1.0.6)
                                  [12:35:21] - WIN_7(X64) - 0409
                                  [12:35:21] - Scrape in x64
                                  [12:35:21] - > No updated files needed (Version : 2.1.0.6)
                                  [12:35:21] - Starting files installation
                                  [12:35:21] - > Ending files installation
                                  [12:35:22] - Error Downloading URL : https://raw.githubusercontent.com/Universal-Rom-Tools/Universal-XML-Scraper/master/Ressources/ServerList.txt
                                  [12:35:22] - /!\ Error Downloading File : C:\MattK\UXS\Ressources\ServerList.txt
                                  [12:35:22] - /!\ Bytes read: 0
                                  [12:35:22] - /!\ Size: 0
                                  [12:35:22] - /!\ Complete: True
                                  [12:35:22] - /!\ successful: False
                                  [12:35:22] - /!\ @error: 13
                                  [12:35:22] - /!\ @extended: 12029
                                  When I go to https://raw.githubusercontent.com/Universal-Rom-Tools/Universal-XML-Scraper/master/Ressources/ServerList.txt it shows:
                                  Fallback
                                  https://www.screenscraper.fr/
                                  https://mirror.screenscraper.fr/
                                  I've tried both the 64bit and normal versions and get the same error message.
                                  Note: This is happening on my work computer, as far as I'm aware, my home computer still works fine, but I haven't used UXS at home for a day or 2.
                                    BORIStheBLADE1
                                    Ok so has anyone scraped their ROM collection on their computer with this program? I've been trying to do it but it's not working right. It will scrap one system but after that it doesnt save any pictures. What folder structure are you also using?
                                    • screechS
                                      screech
                                      @rapidfire Bug referenced (and corrected on the next version I must release) : It's happen when you check "Missing Roms" in the general config, and when the rom is not found (but Added to the XML)
                                      @mattrixk Pretty weird... It's like UXS were blocked by your Firewall/AV ? or Github is inaccessible...
                                      @BORIStheBLADE1 If you use well the wizard, it use the "default" path to store gamelist and picture on your PI (like the Retropie integrated scraper)
                                      Be aware there is a probleme with the "auto kill es function". (When you scrape, UXS offer you to Kill ES, if it doesn't work you need to do it manually. It's already corrected in the next version... Really need to release :S )
                                        BORIStheBLADE1 @screech
                                        @screech
                                        When scraping for the RPI it works fine. Im talking about scraping locally.
                                        Ive used the wizard many times for scraping to the RPI. Im talking about "locally " to my PC.
                                        • hansolo77H
                                          hansolo77
                                          So it's been a while since I've updated my system. I'm trying to get UXS to scrape but I've altered the paths and it's not working. In my setup, I've got all my roms on a hard drive, which is attached to the Pi. My plan was to use the larger capacity of the hard drive to store large games (.iso's, etc) and video screen shots. The way UXS sets up for default on the auto-configure, it tries to store all the artwork on SD card inside a nested folder for EmulationStation. I've changed it so it will put it in a subfolder with the ROMS. However, it's not working. It will go through and scrape everything fine. I can load up the created gamelist.xml and can see where it wrote out the location for the various artwork. But the path I told it use doesn't exist. "/home/pi/RetroPie/roms/%system&/art". Everything up to the "art" bit works, but it doesn't create that new path and save images there.
                                          Is this related to the problem with the SSH commands not shutting down EmulationStation? I've got ES turned off before I scrape. I'm scraping again now, storing the scraped artwork locally on my computer and I will try to move them to the Pi's drive when finished. Is this going to be the only way I can do this?
                                          Who's Scruffy Looking?
                                          • screechS
                                            screech
                                            @BORIStheBLADE1 and @hansolo77
                                            and replace it by :
                                            <AutoConf>
                                            </AutoConf>
                                            For both of you : Change the <Source_RootPath> with the "reel path to your rom's systems folder"
                                            For @hansolo77 :
                                            Change <Source_ImagePath> by : %Source_RootPath%\%system%\art
                                            and
                                            Change <Target_ImagePath> by : ./art/
                                            It must work ;)
                                            (You can do it through the interface ^^ but it's easier to copy/past ;) )
                                            B mattrixkM 2 Replies Last reply Reply Quote 0
