    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 896.6k Views
    • screechS
      screech
      wow... that's really weird :S
      Can you send me your log : screech[@]free.fr ? Just to check ?
      (My neogeo folder scrape well ^^)
      For information : 2.2.0.2 is out :
      https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/releases/tag/2.2.0.2
      Corrected :
      • Full Scrape don't neverend anymore.
      • SSH kill works now on scrape demande.
      • Date with only a 'Year' will work now (the date will be 'Year/01/01')
      • When adding Missing Rom, Name were "(Clone, Beta, Demo, ...)". It's OK now ;)
      • When you force JPG or PNG, Video stay in MP4.
      Modification :
      • New ProgressBar changing color (Green = OK, Red = Timeout or error download, Yellow = Not found)
      Added :
      • New, in case UXS Hang (it never happen ^^), when you re-launch a Scrape, it will ask you if you want to generate a gamelist.xml with the temporary file found.
      • New Shortcut was created at the first launch : 'Silent_UXS'. You can now run UXS silently ;)
      • New Visual info about Engine Use. Some check box corresponding to the Thread Number will tell you if the Engine is used or not.
      • 2 New Advanced Menu : Reset Autoconfiguration Path and Alt Autoconfiguration Path (only for Retropie, it put the Rom's Folder Path)
      • New Element Type : RomExcluded
      Exemple :
      	<Element Type="RomExcluded">
      		<Source_Type>Variable_Value</Source_Type>
      		<Source_Value>%AutoExclude%</Source_Value>
      		<AutoExcludeEXT>bin|img|iso|ccd|sub</AutoExcludeEXT>
      		<AutoExcludeValue>(Track |[Bios]|(Bios)</AutoExcludeValue>
      	</Element>
      Mean :
      When a duplicate name file (without extension) is found:
      - it check the extension. If in list (bin|img|iso|ccd|sub) it won't scrape it
      - it check if the file contain a value ("(Track ","[Bios]","(Bios)"). If yes, it won't scrape it
      • hooperreH
        hooperre
        @screech I used to open this file using the source code zip download by running "Universal_XML_Scraper64.exe" included in the 2.1.0.6 download. I noticed that file is no longer included in the source download and when I try to run either "Scraper.exe" or "Scraper 64.exe" nothing happens.
        How do I open the Scraper?
        4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
        • screechS
          screech
          @screech said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
          just download the Universal_XML_Scraper.exe or Universal_XML_Scraper64.exe that's all.. The other stuff are the source code...
          And scraper.exe or scraper64.exe are the scrape engine and can't work as standalone...
          hooperreH 1 Reply Last reply Reply Quote 0
          • hooperreH
            hooperre @screech
            @screech Thanks. For some reason I can't get those to download because my browsers detect a 'virus.' I'll just have to disable it. I think you're aware of this and it was covered previously in the thread.
            • screechS
              screech
              Yep :( sorry for that :( the language I use (Autoit) is well know by antivirus because in the past a lots of people create malicious software with it...
              So every AV block every Autoit software...
              I contacted some of the main AV compagny to tell them it's a false positive.
              Some respond and it's ok now with some of them...
              Some never answer... And False positive is still here :'(
              so you need to "accept" UXS in your AV. sorry...
              (In case of doubt if there is malicious code, all sources are on the github ^^)
              • hooperreH
                hooperre @screech
                @screech Ya. I sent it to Microsoft alerting a false positive as their Defender AV is picking it up and really not even letting me open it in any fashion. Really not even download it. I added the download URL to the exclusion list, was able to download it to Edge's temp folder. Would it be possible to include the .exe with the source code .zip in the future? Seemed to circumvent the issue.
                • mattrixkM
                  mattrixk @screech
                  I'm at work at the moment, so it will have to wait until later tonight. I might try scraping with a different version (maybe the new one) and see if that makes a difference.
                  On that note, congrats on getting the next version out. I know I bug you a bit, but UXS is seriously one of the best programs I use on a regular basis.
                  • mattrixkM
                    mattrixk
                    @screech: I emailed the log files to you.
                    • screechS
                      screech
                      Great ^^
                      I just received and studied your logs...
                      What I see :
                      Your hash weren't found in the DB...
                      So UXS try to find a matching name. And can't....
                      But you have the "In Zip" Option activated. So it unzip the file, and try to match at least 1 of the file in the ZIP.
                      And he can !!! but, the problem on Neogeo is some eprom are exactly the same from a game to another.
                      Like "000-lo.lo"... (I think it's a Neogeo Bios File)
                      It found this file every time. And UXS/Screenscraper API take the first match every time :(
                      That's explain your duplicate :'(
                      My advice :
                      Try in GENERAL OPTION to
                      • uncheck the "Auto select your system"
                      • uncheck the "Unzip File"
                      • Select in Research Mode : "2 - Filename"
                      So when you launch the scrape it will ask you wich system it is.
                      Select "Neogeo"
                      If you haven't renamed the file (or it's a standard name) like I see in your log, it will work ;)
                      K mattrixkM 2 Replies Last reply Reply Quote 0
                        kbronctjr @screech
                        @screech there are some psx games that the scraper can't find, I even changed their names so they match the name in screenscraper
                        AlexMurphyA 2 Replies Last reply Reply Quote 0
                        • AlexMurphyA
                          AlexMurphy Banned @kbronctjr
                          @kbronctjr screenscraper can be set to use hashes. Did you try that? It may be the default actually.
                          • AlexMurphyA
                            @kbronctjr Have you tried to find them using the built-in scraper or the sselph scraper?
                            K 1 Reply Last reply Reply Quote 1
                              kbronctjr @AlexMurphy
                              @AlexMurphy I don't think I can use hashes, as most of my games are compressed in pbp format
                              And yeah I had all games scraped with the builtin scraper, but I wanted to get the collages this scraper provides and also the games description in my language
                              • TMNTturtlguyT
                                TMNTturtlguy
                                I hate to say this, but sometimes it is just easier to manually enter the ones that the scrapers don't find. They are not always 100% accurate and complete. It is pretty easy to find the videos/images you need for the roms it misses....that is unless you are talking about 100's of misses!
                                AlexMurphyA 1 Reply Last reply Reply Quote 1
                                • AlexMurphyA
                                  @kbronctjr Have you tried? I don't think it caused me any issues. I def have images, the 3 image mix from screenscraper for .pbp and I only use .pbp for PSX.
                                    kbronctjr
                                    The problem is the MIX images. I wish the program included a tool to create those mixes using our own image. In this case I could manually get the images from screenscraper an use them as an input in this tool.
                                    I'm gonna try in hash mode just in case
                                    • AlexMurphyA
                                      AlexMurphy Banned @TMNTturtlguy
                                      @TMNTturtlguy Yeah, I like making my own images too.
                                      • TMNTturtlguyT
                                        TMNTturtlguy @kbronctjr
                                        @kbronctjr well there are solutions for that as well, again not ideal, but if you have access to photoshop it is very easy to do. If you don't have photo shop there is a program called gimp, which is basically a free version of photoshop but not as user friendly. you can collect the images and simply layer them in gimp and save. Takes about 5 minutes of time to do each one. Not fun, but if you are missing 5 roms, it is nice to be able to complete your set.
                                        AlexMurphyA K 2 Replies Last reply Reply Quote 1
                                        • AlexMurphyA
                                          @TMNTturtlguy If you want something easy to use. GIMP can be a bit intimdating, try https://pixlr.com/editor/
                                            kbronctjr @TMNTturtlguy
                                            @TMNTturtlguy said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                                            Yeah I know, I just wanted to avoid wasting time, as I'm already wasting a lot of time downloading and re scraping games and downloading different themes. I spend more time doing this that actually playing haha
                                            It would be nice to have a tool to build your own mixes included in this scraper, as it already has the algorithms to build them
