    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 896.5k Views
    • hansolo77H
      hansolo77
      What is the best way to scrape systems like PSX that have multiple files for a single game? Meaning (for instance)...
      Alien Resurrection (USA) (Track 1).bin
      Alien Resurrection (USA) (Track 2).bin
      Alien Resurrection (USA) (Track 3).bin
      Alien Resurrection (USA) (Track 4).bin
      Alien Resurrection (USA) .cue
      This returns 5 copies of the same file, and 5 entries in my gamelist.xml. I just need one. Also, for SegaCD, I have things like this....
      Wing Commander (1994)(Electronic Arts)(NTSC)(US)(Track 1 of 6)[!].iso
      Wing Commander (1994)(Electronic Arts)(NTSC)(US)(Track 2 of 6)[!].wav
      Wing Commander (1994)(Electronic Arts)(NTSC)(US)(Track 3 of 6)[!].wav
      Wing Commander (1994)(Electronic Arts)(NTSC)(US)(Track 4 of 6)[!].wav
      Wing Commander (1994)(Electronic Arts)(NTSC)(US)(Track 5 of 6)[!].wav
      Wing Commander (1994)(Electronic Arts)(NTSC)(US)(Track 6 of 6)[!].wav
      Wing Commander (1994)(Electronic Arts)(NTSC)(US)[!].cue
      Which, inevitably generates 7 copies of all the artwork, and 7 entries for the same game in the gamelist.xml. It's really quite annoying. So what is the best way to scrape this?
      Who's Scruffy Looking?
        kbronctjr @hansolo77
        @hansolo77 go to the scraper settings and remove the .bin and .wav extensions from the list of file extensions to look for
        • hansolo77H
          hansolo77
          Yeah that's what I'm trying now.. I removed *.wav and *.bin and put them in the excluded line... seems to be working.
            @hansolo77 Also I think that retropie by default doesn't show rom files with .bin extension for psx, so only the entry of the .cue should appear in the front end
            • screechS
              screech
              @hansolo77
              I added in the last version this :
              • New Element Type : RomExcluded
              Exemple :
              <Element Type="RomExcluded">
              	<Source_Type>Variable_Value</Source_Type>
              	<Source_Value>%AutoExclude%</Source_Value>
              	<AutoExcludeEXT>bin|img|iso|ccd|sub</AutoExcludeEXT>
              	<AutoExcludeValue>(Track |[Bios]|(Bios)</AutoExcludeValue>
              </Element>
              Mean :
              When a duplicate name file (without extension) is found:
              • it check the extension. If in list (bin|img|iso|ccd|sub) it won't scrape it
              • it check if the file contain a value ("(Track ","[Bios]","(Bios)"). If yes, it won't scrape it
              normaly it works (on my test)...
              You can add in <AutoExcludeEXT> the WAV format. have you the last one ?
              hansolo77H 1 Reply Last reply Reply Quote 0
                kbronctjr
                @screech sorry to bother you, but do you know why the scraper doesn't detect some roms even when the names are registered in the list of rom names for that game in screenscraper?
                • E
                  EctoOne @kbronctjr
                  @kbronctjr The games you listed before contain special characters (i had the same problems with Chip's Challenge because of the ') and there always was a problem with them. The only thing you can try is to use the hash method instead of just names.
                    kbronctjr @EctoOne
                    @EctoOne The problem is that the psx games are compressed in PBP format and the crc is not the same I guess.
                    The GBA splinter cell is a regular version but still is undetected with hash method
                    • screechS
                      screech
                      I still have problem with Filename Match with the '.
                      It's not only on my side... I ask the API with an URL request, so I can put ' directly in the url or urlencode it.. but in both case, the API don't find it... I need to work with the API dev but he (and me) are really busy these last time... can't manage to find some time to check that.. Sorry
                      Still the Hash method who is the best to be sure match is OK, but with PBP it's a problem (every PBP will be different so we can't add all PBP Hash in the DB, it's a nonsense. They're some, but it's because they are coming from "kown" romset)...
                      K 1 Reply Last reply Reply Quote 1
                        kbronctjr @screech
                        @screech don't worry, you already have done a lot of work by providing this application.
                        For one of the games I tried using and original .cue and hashing it and it worked, then I rename the rom name to the pbp one in the gamelist. Hashing bin takes a lot of time so if I find .cue for the remaining roms I will use that method
                        • hansolo77H
                          hansolo77
                          So I finished scraping all my systems. The new version is a vast improvement from the older one I was using before. It's still a little buggy though. When I looked at the game lists, specifically CD games that have multiple disks, it doesn't display things like "disk 1", "disk 2", etc. So I'm kind of lost there. I'm going to try rescraping that system (psx) with a different rom naming setting.
                          Something else I'd like to ask the community in general... Has anybody experienced weird playback of the videos inside RetroPie? I'm on a Raspberry Pi 3 using the Carbon theme (because it's the least cpu/gpu intensive theme). All of my videos are playing back green, super pixelated, and laggy. Is this something that I can fix, or is it something that's just going to have to be lived with until better support for video comes out? If I have to wait on a solution, is there a way to have it display the image art first?
                          • AlexMurphyA
                            AlexMurphy Banned @hansolo77
                            @hansolo77 I don't use videos but everyone says that the res has to be shrunk to at least 320X240 @ 30fps for them to run correctly.
                            • hansolo77H
                              hansolo77 @AlexMurphy
                              @AlexMurphy Ah.. is there a utility to batch process this?
                              • AlexMurphyA
                                @hansolo77 Again, handbrake is often spoken of.
                                • hansolo77H
                                  hansolo77
                                  Thanks I'll give it a try.
                                  • hansolo77H
                                    hansolo77 @screech
                                    @screech where do I find the settings for this "RomsExcluded" functionality? Is it built into the program, or is it something I have to manually add to the ini? When I scrape SegaCD I still get multiple entries for the same game. Here is an example of the artwork it creates:
                                    https://pastebin.com/UVQY7egb
                                    • RionR
                                      Rion @hansolo77
                                      @hansolo77 Your img files are split in to multiple bin files. Rebuild your Redump games by mounting the image. Select your cue file and mount it. Make new image with imgburn.
                                      That will produce one bin/img file and one cue file.
                                      FBNeo rom filtering
                                      Mame2003 Arcade Bezels
                                      Fba Arcade Bezels
                                      Fba NeoGeo Bezels
                                      • hansolo77H
                                        hansolo77
                                        That sounds too easy. :) Will the emulators for Sega read bin/cue? I thought I read somewhere the files had to be bin/cue/wav.
                                        • screechS
                                          screech
                                          @hansolo77
                                          Normally the RomsExcluded is already in the Retropie.xml Profil.
                                          But maybe it won't work, I haven't so much tested this :S
                                          The best way still to exclude *.wav from the scrape or like Rion Say : Create a cue+bin and scrape the cue.
                                          • hansolo77H
                                            hansolo77
                                            Yeah, my xml has it listed, but it didn't catch it. I'm trying to rebuild bin/cue images now.
