    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 892.3k Views
      Panther7
      This crashes no matter what I do, immediately after starting a scrape.
      It says "hashing" on the bottom line, then stops responding until I kill the process. The log reads as such:
      [03:18:32] - C:\Users\Redacted\Desktop\UXS\Scraper64.exe (1.2.0.10)
      [03:18:32] - WIN_7(X64) - 0409
      [03:18:32] - > systemlist.xml Opened
      [03:18:32] - > Genrelist.xml Opened
      screechS 1 Reply Last reply Reply Quote 0
      • screechS
        screech @Panther7
        @Panther7 are you scraping iso ?
        Big file May Take long time to hash. ...
        Look at the uxs wiki There is several solutions.
          Panther7 @screech
          @screech I actually think I figured that one out. I was using the wrong password for my SSH. I didn't realize I had to independently sign in on that application. I still can't get the correct marquee download though. Didn't mess with it much more. I was only looking at it because the actual built-in scraper wasn't working.
          I've spent all night trying to get the actual built in scraper to work. That thing is all over the place for me. It usually finishes without even scanning the roms (Dreamcast/Playstation). I'm at a loss, as I had it working fine just a few days ago.
            Jste84
            possibly a silly question here @screech and I've tried to find this myself, but is there a way to scrape missing images only?
              UDb23 @hansolo77
              @hansolo77 said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
              How do I manually download the images hosted at screenscraper.fr?
              It's a little bit tricky but can be done.
              take this page as an example. Take note of the horizontal size of the fan art (1920) and then right click on the Fan Art image and select "open image in another tab". You will get here..
              Now edit the URL by replacing the "maxwidth=" in the URL with the actual width you noted (and delete trailing"'&maxheight=190" as not needed).
              Press enter and you get the full res image.
              • FlyingTomahawkF
                FlyingTomahawk
                @screech
                Also getting some error with the latest version.
                AutoIt Error
                Line 26288 (File "C:\Users\XXXXX\Desktop\Raspberry\Universal XML Scraper\Universal_XML_Scraper64.exe"):
                Error: Subscript used on non-accessible variable.
                Also when I set the image size to 960x540 it gets completely ignored and it gives me something like 384x224 size images.
                The previous version of UXMLS worked just fine though.
                • mattrixkM
                  mattrixk @FlyingTomahawk
                  I might be wrong about this, but I thought it wouldn't make the images any larger than their default size. Eg: If you set the size to 1920x1080, a 640x480 image won't download any larger than 640x480.
                  So maybe the images you are trying to download are just 384x224 and won't grow any bigger? Just a thought.
                  FlyingTomahawkF 1 Reply Last reply Reply Quote 0
                  • FlyingTomahawkF
                    FlyingTomahawk @mattrixk
                    @mattrixk
                    That could be but then this must be a new feature.
                    Before I could scrape the exact same images in larger size. And on their website the images are available in larger size. It would be a big pain to go and download each image manually.
                    CORRECTION:
                    You are right the screenshot images are mostly small at 320x224 resolution.
                    So if I create mix images like screenshot+marquee the screenshot gets blown up to match but when scrapping for screenshots only the images are small.
                    Strange, no error message today...
                    • mattrixkM
                      @flyingtomahawk said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                      You have no idea. I'm currently manually creating MIX images and a gamelist for PSP because nothing scrapes it correctly. I have to get all the different images (and data) from numerous sources. It's painstaking.
                      Edit: or you might have some idea. You may have gone through this before, I have no way of knowing.
                        red2blue
                        @screech hey man i submitted about 10 things on screenscraper and they've all been accepted yet i did not receive any new threads ???? I only received 2 from 2 days ago when i submitted one box art photo, but i didnt receive anything from the 10 things i submitted last night... but like i said they are all accepted and i got nothing in return. just that puzzle japan thing pieces
                        • FlyingTomahawkF
                          FlyingTomahawk @red2blue
                          @red2blue
                          Join their chat and tell them that you submited some stuff and haven't received any threads.
                            red2blue @FlyingTomahawk
                            can you give me link for chat?
                            • FlyingTomahawkF
                              @red2blue
                              On their website, top-left where it says CHAT IRC. Click on it.
                              • hansolo77H
                                hansolo77
                                Is the server down or having issues? I'm trying to re-scrape my GBA system, as it only currently has 2 videos. I have a complete romset, but after only scraping 2 games the program crashes. I'm not sure what could be causing it, because I've been able to completely scrape this system already to get boxart and screenshots (and metadata). So I'm just using the "Update Art" settings. I've also tried to use the "Create new XML" setting and that causes a program crash too (closing then checking microsoft for a solution to the problem).
                                Who's Scruffy Looking?
                                • AndersHPA
                                  AndersHP
                                  I just finished scraping my console games (SNES, NES, Megadrive) with success and wanted to scrape Neogeo and MAME, but every image in these categories are 1kB and black..
                                  Is there something specific I have to do to scrape NeoGeo and MAME?
                                  NeoGeo games are placed in the NeoGeo folder, and are all FBA versions off the 0.2.97.39 Romset, MAME is MAME2003 (0.78 romset)...
                                  My Gameboy
                                  • mattrixkM
                                    mattrixk
                                    screenscraper.fr is down at the moment. It was working fine last night.
                                    • mattrixkM
                                      mattrixk @mattrixk
                                      Oop, back now.
                                      AndersHPA 1 Reply Last reply Reply Quote 0
                                      • AndersHPA
                                        AndersHP @mattrixk
                                        @mattrixk I'm still getting all 1kB images when scraping for MAME. Is it down again?
                                        My Gameboy
                                        • mattrixkM
                                          mattrixk @AndersHP
                                          @andershp I'm not scraping at the moment, but I'm having no trouble navigating around the site.
                                            red2blue
                                            k that IRC is completely dead never got a response.
