    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 896.8k Views
    • E
      EctoOne @hooperre
      @hooperre I was using UXS some minutes ago and it worked fine for me. And Skraper is not available yet. At least I got that text when I tried to download it. Can't say anything about the login problems, because I don't have/want an account on screenscraper.
      hooperreH 1 Reply Last reply Reply Quote 0
      • hooperreH
        hooperre @EctoOne
        @ectoone Interesting. Thanks for the response.
        Mine just closes up after the splash screen.
        4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
          timekills
          When scraping for images only, the output is not the mix image selected. It is just the screenshot.
          The same romset works to make the mix image if you choose overwrite the xml file.
          I thought the option to just create images should still create the mix image just like the overwrite XML file choice - it just doesn't overwrite the XML, so you can just replace the current image set with the new ones.
          Any idea why it is not creating the mix image file when you choose option 2, create images only?
          • hooperreH
            hooperre @timekills
            @timekills I had this issue as well. It works when I switch the default to a .jpg output and it will then give me a .jpg case grab and a .png MIX file.
            • hooperreH
              hooperre
              Edit: Fatal Error Resolved
              • GreenHawk84G
                GreenHawk84
                Is there only ONE mix and ONE video snap per game that everyone receives?
                What if 5 people submit art for the same game and one of those is spot on but the others are inaccurate?
                • hooperreH
                  hooperre @GreenHawk84
                  @greenhawk84 said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                  I am not a dev of this project or http://screenscraper.fr, but I'm pretty sure information is submitted and approved by mods at the website and only the one they deem to be more accurate stays. Often times I will create custom ones.
                  • GreenHawk84G
                    GreenHawk84
                    Some of the video snaps that were "scraped" are not playing.
                    Examples: astorm, altbeast, btime, centiped.
                    If I copy the downloaded .mp4 file from my Retropie installation to my desktop and play the .mp4, I will hear sound but see no video. This is different for a video snap that does play in Retropie; everything plays as normal when I copy to my desktop for testing.
                    hooperreH QuackwalksQ 2 Replies Last reply Reply Quote 0
                    • hooperreH
                      I've had the same problem for a while. I go and get the snaps elsewhere in this case. :\
                      GreenHawk84G 1 Reply Last reply Reply Quote 0
                      • GreenHawk84G
                        GreenHawk84 @hooperre
                        @hooperre I wonder if there is a tool that can be created to search for specific images and videos in the databases that scrapers access?
                        Say I want Super Mario artwork and I want to see what has been submitted. I would type in Super Mario and the window would populate with available box art/videos/logos. I could click on that file and bring it up on my PC to preview it before dropping it into Retropie via WinSCP.
                        Is this possible?
                          mitu Global Moderator @GreenHawk84
                          @greenhawk84 Use a browser to access the sites used for scraping, the same artwork should be available and searchable.
                            Pyjamarama
                            Universal XML Scraper V2 scrapes my Amiga .lha files (form the RetroPlay pack) up to letter C. Strange
                            • QuackwalksQ
                              Quackwalks @GreenHawk84
                              @greenhawk84 I'm having the same problem with the same games. The video and sound play fine when copied to my pc. Also, when the OMX player is disabled the videos will play in emulationstation. Something ain't quite right with certain video snaps. (edit) I've learned that some videos are encoded differently, using YUV 4:4:4 instead of YUV 4:2:0, and that I need to convert them to work with OMX player. I guess that answers that.
                              hansolo77H 1 Reply Last reply Reply Quote 0
                              • hansolo77H
                                hansolo77 @Quackwalks
                                @quackwalks There is a script here in the forums somewhere that will go through your videos and automatically reencode the ones that need it. I don't remember where I found it or what it's called, but I know it's there. You can probably find it if you look for it. It's really easy to use, and a lifesaver. I had the same problem till I learned that.
                                Who's Scruffy Looking?
                                QuackwalksQ 1 Reply Last reply Reply Quote 0
                                • QuackwalksQ
                                  Quackwalks @hansolo77
                                  @hansolo77 It's right here, https://retropie.org.uk/forum/topic/15362/script-batch-convert-yuv-4-4-4-videos-to-yuv-4-2-0-in-retropie-linux. I just finished using it and it worked perfectly.
                                  • E
                                    elahrairah
                                    So I downloaded video and 3d box with xml scraper for psx and all went well but the gamelist.xml shows the wrong paths to my video art.
                                    I use on my retropie setup (with external hdd) two seperate folders for images and video:
                                    Image : folder "boxart
                                    Video: folder "snap"
                                    Both these folders are in the system rom folder: /roms/psx
                                    This is the conventional method almost every retropie user uses.
                                    But when looking at the paths to the video and art in the gamelist I see they both point to same location which is /retropie/roms/psx/boxart. This means I have to put all the art in the same "boxart" folder, which I do not want.
                                    So I did try to fix it myself and change the path in configuration to "boxart" location which is the right path for the 3d boxes. But I want the gamelist to also create a seperate path to the video in the gamelist.xml, so it points to my art folder "snap"
                                    How do I do this?
                                    Long question in short: how do I change the paths in the gamelist.xml so each type of art is linked to a seperate folder?
                                    • E
                                      EctoOne @elahrairah
                                      @elahrairah there is no way to set differnt paths in the scraper as far as i know. you have to manually edit the video paths in the gamelist.xml. Doing a search/replace should be the easiest method. I suggest to search for <video>OLDPATH/instead of just OLDPATH/ this will prevent that the path to your images will also be changed.
                                      E 1 Reply Last reply Reply Quote 1
                                      • E
                                        elahrairah @EctoOne
                                        @ectoone don't know if I will go through those lengths but I appreciate your answer, at least now I know it's not possible, so I think I'll just put all art in 1 folder.. No big deal.
                                        • E
                                          EctoOne @elahrairah
                                          @elahrairah with something like notepad++ it is very simple to achieve though. It lets you search/replace in multiple files and what not. I did the same thing for all four media files (boxart, marquee, thumbnail and video) and have them in separate folders now.
                                          • hooperreH
                                            hooperre
                                            @screech Is there a way to add a game for PC for example on the screenscraper.fr website? I see Windows 3.1 and stuff.
                                            Also, I haven't been able to login from Google Chrome for about a year. I have had to use Microsoft Edge. :\
