    [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture
    scrapescraperuxs
    728 Posts 111 Posters 906.6k Views
    • F
      firewater
      Is there any way so that the images of arcade are not antialiased? I tried forcing them to be downloaded in .png but they still are, and it looks awful since I only want to grab the thumbnail with no logo and the game doesn't look nearly as clear with all that "jpg" kind of compression on the borders... or are they this way on the database?
      • hansolo77H
        hansolo77 @Nismo
        @Nismo said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
        @hansolo77 said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
        @vbs If that's the case, I'll just stick with my current batch of scrapes until Carbon is updated to allow videos. Because I have a bunch of systems installed on my RetroPie, I pretty much have to use Carbon. I don't like it, but it's the only theme that seems to work.
        Carbon theme with video support:
        http://www.mediafire.com/file/f32kjrkeopykjra/carbon_with_video.zip
        Enjoy.
        Awesome!! I'll give this a go on my next day off... Does this also include the added tags that are in the kids version of EmulationStation? If not, no biggie!
        Who's Scruffy Looking?
        • N
          Nismo @hansolo77
          @hansolo77 I suposse it has i only downloaded carbon from github and i added video support...
          • screechS
            screech
            @firewater what do you meen by antialiased ?
            By default, MIX template use a png compression at the end of scrape. It may be that.
            you can de-activate compression by editing the config.xml in the template you use by putting "false" on the <compression> node
            F M 2 Replies Last reply Reply Quote 0
            • F
              firewater @screech
              @screech I've looked at the site and it seems that all images for arcade are like this from the database. So what I mean was that, this is how they look for arcade, and this is how it looks for a game on GBA. You can clearly see one has the pixels as presented on the game and the other has a bilinear filter on them (which looks awful, in my opinion).
                MartinS @screech
                This post is deleted!
                  paradadf @firewater
                  @firewater you can always submit new images to the DB ;)
                  If you have better images, you can contact the people from SS to make a mass proposal for validation. This is easier if you are submitting hundreds of images. The only thing is that the names must (more or less) correspond.
                  • screechS
                    screech
                    @firewater don't know where these Screenshot came from (I haven't submit it ^^) :S
                    Maybe it's a screenshot from an emulator (certainly) and there is some effect on it :S
                    For me, It didn't seem to have "so much" antialiasing...
                    And you compare a CPS1 game with a nintendo GB advance game ;)
                    But effectively, you are welcome if you have better Screenshot to submit some to the DB ;)
                    (there is a huge job to do on arcade system... The DB have just 1 year old ^^ lot's of work is comming ;) )
                    • F
                      firewater @paradadf
                      @paradadf @screech yes, be the change you want to see and such. Well to be fair I contribute on the film database of TMDB so I'm not that much of a leech of databases haha Not to mention I do appreciate that at least there are images, it's just I wanted to know if it was the program's problem or the database.
                      I downloaded a .zip that has 2000~ snapshots of MAME (don't remember where, it was yesterday, but it's probably failry common). Since the ROM name coincide, I think it's just a matter of appending a "-image" at the end to all files for ES to pick them up and problem solved... I hope.
                      On the other side, does anyone have a mix profile that has 2D box art + snapshot? This is I what I want (box at top, snapshot at bottom). I'll try making one myself if not.
                      • screechS
                        screech
                        @firewater you can help the DB with your ZIP ;)
                        We can add directly your zip to the "Mass Import" system... Just need to associate them (with an auto association engine, if your image file are well named it's a question of "minutes" to update these 2000~ snapshot directly on the DB ;) )
                        For the MIX, sorry, I haven't one like that, but it's pretty easy to make the change ;)
                        just have a look here : https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/wiki/[TUTO]-Making-a-MIX-Template
                        If you have problem, you can contact me (or if I have some time I can do it ^^ )
                        If you managed to do it, don't hesitate to share it directly on the Github MIX Repository (https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/tree/master/MIX Repository ) So every one can dl it and use it directly from UXS ;)
                        (Or if you can't push it to github, send it to me ;) I'll add it ;) )
                        • F
                          firewater @screech
                          @screech I found the zip and it turns out it was a mirror of these. I think these are the standard snaps most use, so it's weird that there are other ones (the ones already uploaded, with bilinear filtering and so on). The whole pack is uploaded on Mega and is updated to the penultimate romset version so I think it's fair to assume it would be a good update from the ones that are included already... but I'll leave my involvement of this part at that, I'd rather get the the mix template (and the rest of my setup) working first.
                          So I'll get back to you soon... or in some hours depending on how difficult it is, with a MIX template result!
                            dankcushions Global Moderator @firewater
                            @firewater said in [SOFT] Universal XML Scraper V2 - Easy Scrape with High Quality picture:
                            right! this is a huge annoyance of mine with a lot of scraping databases. for any pre N64 era game, all screenshots should be lossless .PNGS at the exact resolution of the original game, and they should be about 30KB max. and other format will be loads worse looking and/or a larger filesize.
                            with stuff like mame, i've found some good snaps out there. see https://github.com/libretro/RetroArch/issues/4333#issuecomment-270173083
                            • F
                              firewater
                              @dankcushions Yes! I agree completely. I also didn't know all (or most) databases did this, I've only ever dealt with boxarts most of my short frontend life so I assumed it was a specific problem on this one.
                              edit: well this is what I've got so far, it puts the box at the top and the screenshot at the bottom... more or less. Problems I've found is that 1. on NES, the boxart is not found 99% of the time (so it's empty) and 3. for arcade there's never a boxart at top (sure they don't have a "boxart" but it could put on a flyer, though I don't know how those are called).
                              <?xml version="1.0" encoding="UTF-8"?><Profil Name="Dual Vertical (2img)">
                              <Infos>
                              <Author>Anonymous</Author>
                              <Description>2 images assembled : 2D Box, and Screenshot</Description>
                              </Infos>
                              <General>
                              <Empty_Exemple>Empty_example.jpg</Empty_Exemple>
                              <Full_Exemple>Full_example.jpg</Full_Exemple>
                              <Target_Width>650</Target_Width>
                              <Target_Height>825</Target_Height>
                              </General>
                              <Compression>
                              <use>no</use>
                              <soft>pngquant.exe</soft>
                              <parameter>--force --verbose --ordered --speed=1 --quality=30-90 --ext .png</parameter>
                              </Compression>
                              <Root>
                              <Source_Value>Data</Source_Value>
                              <Target_Value>gameList</Target_Value>
                              </Root>
                              <Game>
                              <Source_Value>Data/jeu</Source_Value>
                              <Target_Value>gameList/game</Target_Value>
                              </Game>
                              <Country>
                              <Source_Value>Data/jeu/region</Source_Value>
                              </Country>
                              <Element>
                              <Name>box2dTEMP</Name>
                              <Source_Type>XML_Value</Source_Type>
                              <source_Origin>Game</source_Origin>
                              <Source_Value>Data/jeu/medias/media_boxs/media_boxs2d/media_box2d_%COUNTRY%</Source_Value>
                              <Target_Width>%0.5</Target_Width>
                              <Target_Height>%0.5</Target_Height>
                              <Target_TopLeftX>CENTER</Target_TopLeftX>
                              <Target_TopLeftY>UP</Target_TopLeftY>
                              <Target_Maximize>Yes</Target_Maximize>
                              </Element>
                              <Element>
                              <Name>screenTEMP</Name>
                              <Source_Value>Data/jeu/medias/media_screenshot</Source_Value>
                              <Target_TopLeftY>DOWN</Target_TopLeftY>
                              </Element>
                              </Profil>
                              • mattrixkM
                                mattrixk
                                @screech: I noticed you've updated the MIX tutorial, and that is awesome, thank you. However, I can't seem to get the Target_OriginX and Target_OriginY to work. I'm tyring to position the screenshot. If I don't use Target_Origin, the image shows up fine, with the Origin Point in the top-left of the image (basic default position).
                                If I use:
                                <Target_OriginX>%0.500</Target_OriginX>
                                <Target_OriginY>%0.500</Target_OriginY>
                                Then the screenshot image disappears completely.
                                If I use:
                                <Target_OriginX>CENTER</Target_OriginX>
                                <Target_OriginY>CENTER</Target_OriginY>
                                The screenshot shows up, but it ignores the Target_Origin, as though it isn't there.
                                Do I need to put it in a specific place in the element? Does it have to go before or after the Target_Width/Target_height? What about before/after the Target_TopLeftX/Y? Or does the position in the element not matter?
                                • screechS
                                  screech
                                  @firewater nice job ;) I'll give it a try (not sur %0.5 on both size is the best ;) I think %1 on width and %0.5 on height with the Maximize will be better ;) (exemple on SNES with horizontal Box)
                                  For the flyer, they are comming ;) (it's a new thing on Screenscraper and we are pretty poor on that.)
                                  What about the Marquee ? Put Marquee if no 2D Box ? on top of Screenshot it may be nice.
                                  @mattrixk I found a bug on the 'target origin' can you retry with the very last version ? Normally it will work better ;)
                                  (No need of a specifique position IN the Elements node)
                                  F mattrixkM 2 Replies Last reply Reply Quote 0
                                  • F
                                    firewater @screech
                                    @screech thanks! Oh yes I could try other values for that, maybe that's what's causing NES not to pick up box art (because I remember when I had a smaller size they would always be picked up)?
                                    Ahh that's okay. Flyer is the word I was looking for, but I'll wait for now.
                                    I scrapped my arcade roms, and they all have their cryptic "fgtlayer.zip" kind of names, did I do something wrong or is this how it works? I wish they were changed to the name of the games.
                                    • mattrixkM
                                      mattrixk @screech
                                      @screech I updated to the latest UXS. I think Origin just works differently to how I was expecting it to. I thought it would work the same way <pos> and <origin> work in EmulationStation themes, where <origin> sets the Origin Point of the element and <pos> sets where the Origin Point sits on the screen.
                                      I posted about how <pos> and <origin> work in ES here (complete with visual aides).
                                      It seems like Origin in UXS sets the Origin Point of the screen, not the element, so every element is positioned relative to it. This unfortunately makes it virtually impossible to do what I wanted (and I can't figure out how it would be useful considering you can't do negative positioning).
                                      What I want is to set the size of the screenshot image (eg: %25 wide, %35 high) with <Target_Width>, then position the center of that image in a specific part of the screen (eg: X = %40, Y = %55). I'm using <Target_Maximise>Yes</Target_Maximise> to keep the ratio.
                                      I would do this in an ES theme like this:
                                      <maxSize>0.25 0.35</maxSize>
                                      <origin>0.5 0.5</origin>
                                      <pos>0.40 0.55</pos>
                                      So in UXS I used the code:
                                      <Target_Width>%0.25</Target_Width>
                                      <Target_Height>%0.35</Target_Height>
                                      <Target_OriginX>%0.5</Target_OriginX>
                                      <Target_OriginY>%0.5</Target_OriginY>
                                      <Target_TopLeftX>%0.40</Target_TopLeftX>
                                      <Target_TopLeftY>%0.55</Target_TopLeftY>
                                      Expecting it to do the same thing. It doesn't. Instead it pushes the screenshot image off the bottom-right of the screen because the position is now taken from the middle of the screen instead of the top-left.
                                      I tried setting both TopLeft and TopRight, but that just stretched the image, ignoring both Target_Width and Target_Maximize (but kept the correct height).
                                      So, my question is: Is there a way to set the Origin Point of the Element, rather than the screen?
                                      • screechS
                                        screech
                                        @mattrixk OH !! Yes... You Are right ^^ (My Origin refere to the Screen origin to allow CENTER/LEFT/RIGHT on this Origin point ^^)
                                        I think I never understand well how Origin works in theme ;)
                                        I'll do some modification on the Mix Template function so ;)
                                        Wait for the next release ^^
                                        • mattrixkM
                                          mattrixk @screech
                                          That's great to hear @screech.
                                          While I have you, I have 2 questions about what the scraper can do:
                                          1. Can you use the scraper to download the game videos? Maybe save them out as .mp4 or .gif?
                                          2. Can you use the scraper to save individual images separately? Let me explain. Your default "Standard (3img)" MIX profile downloads 3 different images (screenshot, 3d box art and wheel logo) and combines them into a single image. Would it be possible to make the scraper download those same 3 images, but save them out separately? Either into separate folders within "downloaded_images", or with "-screenshot", "-boxart", "-wheel" appended to the end of the filenames?
                                            Concat
                                            So... when the scraper can't find a match, the recommendation is to change the file name?
                                            When I do that, it seems as though I have to change the extension as well... and then change it back, and manually edit the gamelist so the extension is corrected there as well. Mind numbing progress on my Dreamcast games and PS games...
                                            Then save states won't work after, so have to change name again and manually edit gamelist. Hmm...
                                            Anyone figure out a faster way to resolve these orphaned roms?
