    Command problems.
    command linescraping
    6 Posts 2 Posters 1.6k Views
    • soulfunkdjxS
      soulfunkdjx
      Hi, i have raspberry pi3 and i have installed retropie (latest version) and the pixel desktop.
      I followed the installation of Steven Selph's Scraper from here
      https://github.com/retropie/retropie-setup/wiki/scraper
      I installed it right and then i quit emulationstation and tried to access to Steven Selph's Scraper from the retropie setup script.
      So i add the command line sudo /home/pi/RetroPie-Setup/retropie_setup.sh as the link above provided me but i get a "command not found"
      I then went to my file browser in Pixel desktop and i noticed that the file is there. So the command line theoritically is right.
      If i enter another command line as "emulationstation" or "startx" or "df -Bm" are working great.
      What is the problem here?
        meleu @soulfunkdjx
        @soulfunkdjx what command wasn't found? You should post exactly the complete error message you received.
        • soulfunkdjxS
          soulfunkdjx
          Yes of course. This is it
          sudo: /home/pi/Retropie-Setup/retropie_setup.sh: command not found
          • soulfunkdjxS
            soulfunkdjx
            Ok i just found my mistake...
            I wasn't writing the capital P On RetroPie-Setup.
            My bad. Sorry...
              meleu @soulfunkdjx
              @soulfunkdjx a tip: you can use <tab> while writing the command and shell will try to complete what you are trying to type. It can avoid this kind of mistakes sometimes. ;-)
              Cheers!
              • soulfunkdjxS
                soulfunkdjx
                Wow very useful tip. I am very new to all this.
                Thank you very much!
