    Problem installing the drivers for the controlblock, controllers not responding
    joystickcontrolblockdriverarcade
    11 Posts 5 Posters 3.2k Views
      Jeddo
      Did you Check the Hardware Setup with a Voltmeter for any problemls ?
        petrockblog Global Moderator
        Yes, first thing to look at is the revision number of your ControlBlock. If it says rev. 1.* then you need ControlBlockService1. If it says rev. 2.* then you need ControlBlockService2.
        You can uninstall the driver, e.g., by going into the ControlBLockService folder and calling
        sudo make uninstall service
        sudo make uninstall
          Monnaldo
          @Jeddo Not yet. Since I don't own a Voltmeter, I wanted to try the solution in the topic I linked first. But it is something I will need to check if it doesn't work.
          @petrockblog Thanks a lot! I'll try this and keep you updated.
            Jeddo
            Try to get One(Simple ones are quite cheap). It is often easier to Check for Hardware Problems first before diving into Software
              TheRealpvs
              I'm also having the same problem
              I got the service started. And it registers 2 game controllers.
              But no response in jtest or in reptropie. I have rev2.1
              And definitely installed ControlService2
              I have an offical raspberry pi power adapter. But I'm going to go buy a voltmeter as well and see if it might be something else.
              Did you come right on your side?
                cqb30 @TheRealpvs
                @TheRealpvs I have the same problem. Everything hooked up, drivers downloaded, rev 2.1 and the test shows nothing happening even though its registering my game pad. Anyone know how to solve this?
                  cqb30 @cqb30
                  @cqb30 @petrockblog also, I'm confused as to whether or not , in addition to the power supply to my raspberry pi , I need a micro USB power supply in the control block as well because I've seen projects where they do and then on petrockblogs twitter he replied that you did not to someone
                    If you want to use the power switch function of the ControlBlock, then the only micro USB cable for power must connected to the ControlBlock.
                    If zou do not want to use the power switch function of the ControlBlock, then the micro USB cable needs to be directly connected to the Rai itself.
                      petrockblog Global Moderator @Monnaldo
                      @Monnaldo
                      Can you post an image of your hardware setup here? All buttons and the joystick need to be (daisy-chained) connected to GND.
                        There was a recent update of the driver. Maybe things are working for you with that then?
