    Sound Settings, audio level drops a point ever time I return there.
    sound settingsaudio levelbugweirdness
    3 Posts 2 Posters 1.4k Views
    • W
      Wizardling
      G'day.
      I've noticed every time I revisit RetroPie's sound settings from the Start Menu of my GamePad, the audio level drops a point. So if I start at 90%, exit sound settings, then re-enter, it is at 89%, and so on.
      What's happening here? curious
      Frog blast the vent core!
        BuZz administrators @Wizardling
        @Wizardling I assume it's just a rounding issue from converting the saved alsa value to a percentage - just ignore it :)
        • W
          Wizardling @BuZz
          @BuZz said in Sound Settings, audio level drops a point ever time I return there.:
          Yeah, but each visit drops the audio level another point. It's not just once. It is every visit, forever, after the initial change. If one installs RetroPie and never changes the default 75% audio level, this doesn't happen. But as soon as one changes the audio level, it drops every single visit, thereafter.
          Or if you're saying ignore it regardless of all that, well, I call this a fairly serious sound settings bug. Nothing should be altering settings on it's own every time the user visits settings :-)
