    Commodore 64 - GameBase64 v15 - Renamed using Commodore 64 Hyperspin GBv15 and fixed with correct file extensions
    commodore 64datextensions
    23 Posts 10 Posters 11.3k Views
    • RionR
      Rion
      This is a fixed GameBase64 v15 dat file that has been first run with Hyperspin GBv15. Then added the missing extensions.
      How to rebuild you GameBase64 v15 using clrmamepro. Download here.
      • Start clrmamepro
      • Select "AddDatFile"
      • Browse and select the fixed dat file
      • Press OK to add to [PROFILES]
      • Select [NEW DATFILES]
      • Select Commodore 64 Hyperspin GBv15 (double click)
      • Select "Default"
      • Press Rebuilder
      • Folders Source: Browse to you GameBase64 v15 "Games" folder
      • Destination: Where you want to place the rebuild files.
      • Deselect: Compress Files
      • Press "Advanced"
      • Deselect: Remove empty source folders
      • Select: No SetFolder for decompressed sets
      • Press: "Rebuild"
      FBNeo rom filtering
      Mame2003 Arcade Bezels
      Fba Arcade Bezels
      Fba NeoGeo Bezels
      • RionR
        Rion
        Update
        Here is both Screenshots and Box-art for many games.
        Screenshots 7719 of 7846 135 mb
        Box-Art 4150 of 7846 1.39 GB
        You can easily create a gamelist.xml file for these using @Rookervik 's Gamelist XML Creator
        This can be found here
        FBNeo rom filtering
        Fba Arcade Bezels
        Fba NeoGeo Bezels
        • vbsV
          vbs
          One question please: How does this differ from the vanilla Gamebase set (what does it mean to run it through Hyperspin)? Thanks!
          • RionR
            Rion @vbs
            @vbs Nothing really. It just changes the file names to something more readable.
            More up the alley with No-intro naming standard.
            FBNeo rom filtering
            Fba Arcade Bezels
            Fba NeoGeo Bezels
            N 1 Reply Last reply Reply Quote 1
            • vbsV
              vbs
              Hm, some weeks ago I also created a DAT from Gamebase64 v15. As far as I know it contains about 25000 games. Your DAT contains "only" about 8000 games. The 25000 games set contains a whole bunch of crap anyway, so no problem (I filtered it a bit to drop all unpublished titles). But I wonder why it is that different?
              If anyone is interested I can post my DAT and also a python script to generate a gamelist.xml with all the information from the Gamebase VERSION.NFO file with links to the screenshot.
              BTW The VICE script in RetroPie is able to also handle ZIP files (they will be extracted and handed over to VICE), so it is possible to use the original Gamebase64 ZIPs (while the filenames are really awful, but its ok when using a gamelist.xml).
              EDIT:
              Oh I lied sorry, I didn't write a Python script to generate the gamelist.xml (I did for Amiga Gamebase actually), but I used this: https://blog.spreendigital.de/2016/01/04/convert-your-gamebase64-c64-rom-files-to-emulationstation-retropie-recalbox-format/
              (I just patched it to display release date propertly)
              RionR 1 Reply Last reply Reply Quote 1
              • RionR
                Rion @vbs
                @vbs Hyperlist has always been about taking out the crap basically. I also use it on No-Intro sets to get One game One region and then making some personal changes.
                But you are right this is definitely not a complete Gamebase set but uses Gamebase as a source and then cleans it to samething more manageable. But then again this is a personal preference.
                But i would love to see your dat file posted with everything your where describing.
                The more choices people have the better 😉
                FBNeo rom filtering
                Fba Arcade Bezels
                Fba NeoGeo Bezels
                • vbsV
                  vbs
                  I would like a stripped down GB64 since I think it's just too much stuff in there. So I will take a look at the Hyperspin list, thanks! I just noticed though that according to this list https://hyperlist.hyperspin-fe.com/ Hyperspin seems GB64 v14 based, or is there anywhere a newer list also?
                  So these are the DATs I created from the untouched GB64 v15.
                  It contains:
                  gb64.dat
                  gb64pub_only.dat
                  gb64unpub_only.dat
                  gb64.datcontains all games. The gb64pub_only.datis filtered and contains only games that were actually published, the rest went to gb64unpub_only.dat.
                  Then there is this shell script that creates a gamelist.xml for C64.
                  It extracts the information from the VERSION.NFO to fill the gamelist.xml. I got it from here but tweaked it to show publisher and release_date correctly.
                  RionR G 2 Replies Last reply Reply Quote 1
                  • RionR
                    Rion @vbs
                    @vbs Yes thats right v14 is the latest on the hyperlist. But if you register there is a v15 dat file in the upload section.
                    FBNeo rom filtering
                    Fba Arcade Bezels
                    Fba NeoGeo Bezels
                    • N
                      Nismo @Rion
                      @Rion Thank you very much for share with us.
                      • W
                        weirdocollector
                        How do you transform XML Hyperlist to DAT files ?
                        I'd like to use clrmamepro in order to clean my Atari800 ROMS: do I have to use a DAT file, or may I also use the XML from Hyperlist ?
                        Thanks for any help.
                        • W
                          weirdocollector @weirdocollector
                          @weirdocollector said in Commodore 64 - GameBase64 v15 - Renamed using Commodore 64 Hyperspin GBv15 and fixed with correct file extensions:
                          Nevermind, I've found it myself :)
                            Gothrek @vbs
                            @vbs said in Commodore 64 - GameBase64 v15 - Renamed using Commodore 64 Hyperspin GBv15 and fixed with correct file extensions:
                            gb64.dat
                            gb64pub_only.dat
                            gb64unpub_only.dat
                            Hi, where i can download your GB64 v15 .dat files.
                            i try to found a dat for no parent list.
                            tks a lot.
                            vbsV 1 Reply Last reply Reply Quote 0
                            • vbsV
                              vbs @Gothrek
                              @gothrek said in Commodore 64 - GameBase64 v15 - Renamed using Commodore 64 Hyperspin GBv15 and fixed with correct file extensions:
                              gb64pub_only
                              Sorry I deleted the original file accidently but I re-upped it here:
                              https://www.dropbox.com/s/mfwdfw5st1sw3en/GB64v15.rar?dl=0
                                Gothrek @vbs
                                @vbs
                                many tks man. i try it and give to u feedback.
                                edit: error importing file, wrong format
                                  Bfollow1988
                                  @vbs Thank you for the dats and explanations, can you share your tweaked script?
                                  The release date mixed with the publisher bothers me a bit.
                                  Thank you in advance
                                  • vbsV
                                    vbs
                                    It is a while ago and I am a bit confused with my stuff but I think this should be the script:
                                    https://www.dropbox.com/s/uvgn8vfz4h21kcy/gb64conv.sh?dl=0
                                      Bfollow1988 @vbs
                                      @vbs that was quick lol. Yes that's it.
                                        MtKiddy
                                        Could I get some assistance?
                                        I open up clrmamepro and add the .dat file, when I select it and click the 'load/update' button, I click 'default' and get a warning message:
                                        "Rom:
                                        CHROMEBR_01467_01\CHROMEBR.T64
                                        wasn't imported "
                                        I can click ok, and it pops back up with the next rom. I can press ok on all of them and it will eventually finish. When I try to run the rebuilder, nothing changes, the names are all the same.
                                        Anybody know what is going wrong here?
                                          gold64 @MtKiddy
                                          @mtkiddy Yeah I'm seeing the same thing here, not sure what to try. I'm not familiar with this app at all.
                                            grant2258 Banned
                                            i dont know why you guys dont just use the nointo 1g1r dat from the website. Is there any reason not to do it this way?
