    KOF 98 on @Retropie 4.1 help??
    retropie 4.1neo geomameroms help
    8 Posts 4 Posters 7.2k Views
      rainel
      I just can't seem to get KOF 98 running on any emulators on retropie 4.1. I'd tried lr-fbalpha, PiFBA, GnGeo-Pi, lr-mame2003, lr-imame4all,
      lr-mame2010, AdvanceMAME. None seems to be able to run King Of Fighters 98.
      Anyone manage to get it running please advise me how to do it.
      Many thanks.
        obsidianspider @rainel
        @rainel Works fine for me on my Pi 3 running RetroPie 4.1.5 (e5fb6a0) using lr-fbalpha
        Remember that Neo-Geo games require the Neo-Geo BIOS.
          rainel
          thanks for sharing...may i know which rom u used? kof98.zip?
            @rainel kof98.zip. I used the one from the MAME 0.78 reference set.
              rainel
              nope still can't get it to work....i can play kof 94-97 and 99-2003, but can't get kof98 to work...is there any settings i need to take note of?
              tried running both roms kof98.zip & kof98n.zip on lr-fbalpha with neogeo bios in the rom folder...still not able to run it. My pi 3 is already running on 4.1.5 and updated all emulators already.
              Anyone can enlightened me?
                UDb23 @rainel
                @rainel Have you checked if there's any specific error logged in /dev/shm/runcommand.log ?
                  rainel
                  hi guys, thanks for help. finally got it fixed. download the entire romset and it works....weird that i download the single rom from some popular website but doesn't work
                  • rbakerR
                    rbaker @rainel
                    @rainel said in KOF 98 on @Retropie 4.1 help??:
                    It's not wierd. Downloading single roms is like trying to find a needle in a haystack. How do you know which version you are downloading? If it was not a 0.78 rom, like the one you grabbed, it will not work.
                    https://github.com/retropie/retropie-setup/wiki/Managing-ROMs
